Old November 30th 2005, 13:50
Fitting a CSP Kafer Brace
Any body modifications required to fit a 3-bar CSP Kafer Cup Brace in a '69 Bug? I remember reading about needing to remove some metal around the shock towers, but don't recall the specific application.
Also, any clearance issues with the CSP bar and a A1 Sidewinder header?
Kafer_Mike
Old December 1st 2005, 12:31
Turbo Haraune's Avatar
Turbo Haraune Turbo Haraune is offline
Just som small clearancing needs to be done to the sheet metal to make place for the upper brackets.
Check out my project pic`s!
http://www.v-dubs.no/haraune
Old December 2nd 2005, 10:24
same experience here. just on the right side though. very small notch.
Old December 2nd 2005, 12:32
samcat's Avatar
samcat samcat is offline
Same as above, small amount of notching required. 30seconds with an angle grinder and its done
Sam C
Old December 2nd 2005, 12:50
Whew! Thanks guys. The car is in for paint and I was having nightmares about having to carve up the wheel wells...
Kafer_Mike
