best way to lower the SuperBeetle?
Hi gang, my first post here. Happy to have found a VW site just for my kind of Beetle!
I'm starting to think about disc breaks for the front-end, I already have most of the stock Ghia parts to do this (I'll explore the more sophisticated disc break systems later in life, going 'stock' for now). But since I'm "going-in" to the front like this, lowering the car is also something I'd like to do... My question: What's the best way to lower a SuperBeetle? Spindles or suspension (struts)? If it's spindles, needless to say I'll have to buy aftermarket. But if it's struts, I have a 1973 Super, and I'm not sure just yet if it's an early or late model (gotta check my vin# and get back to this) so I understand that the struts differ on this car... Cheers, Joe. -------------------------------------- 1973 Super Beetle convertible San Francisco, CA |
My two cents..
Topline, doesn't matter if early or late.. they have both applications.. Early has three bolts that hold the ball joint.. while the late is a two bolt set up.. kinda like what is seen on most new cars.. Alex
78 Vert, In pieces and on hold also a 73 Saloon, currently being built.. |
So it's struts, not drop-spindles then?
Why one over the other? Cheers, Joe. |
idk maybe im just dumb but i dont think they even make drop spindles. i havent found them anywhere
In super beetle world, when you talk of lowering, spindles dont count anymore. www.toplineparts.com <===visit here to view all your options. There are several ways to lower your super:
1)cut the springs: ghetto superstar! Cut a few coils out the spring, very bad idea, totally kills the ride, and is bad for the suspension 2)lowering springs: here's a start. Check out topline. Top of the line products for supers. they offer regular springs, and tapered sport springs, which tapper in the center, to allow a larger offset wheel to be used, but it still limited to how much clearance you are allowed. 3)adjust-a-strut the first adjustable strut for supers. started by topline, copied to hell. 3-bolt allows up to 5 inch drop, 2-bolt later style allows up to around 3.5-4 maybe. Very safe, effective way to lower your super. Once this came around, topline discovered ways to rearrange the suspension geometry with little tricks here and there...ie caster-fix bushings for the swaybar, off-center hole in bushings forces swaybar more forward, making up for the natural pull rearwards the suspension causes when lowered. 4)MAXX struts, skinny coil-over style setup, allows use of large + offset wheels (ie prosche) more tricks in perfecting suspension geo, bumpsteer kit, toplines caster+ kit, etc. Main rule: do everything right the first time. And do not try and setup a suspension with new coil-overs, etc until everything else is inspected, repair/replaced/upgraded. This goes for tie rod ends, ball joints(tears in rubbber boots=bad), bent/damaged tie rods, bushings (meaning ALL the bushings, especially that idler arm bushing, this is the main cause of the shimmies! Replace everything!!! Again, check out www.toplineparts.com....
=EuroLook71= 71' Super Beetle 1.6L DP - Kadrons, stock heads P&P by me
If your going with option #3 or 4 then you'll want one of toplines sway bars for lowered supers, your control arm bushings will thank you.
