Old December 10th 2005, 11:43
Turbo Haraune's Avatar
Turbo Haraune Turbo Haraune is offline
Air intake
Soon i wil be starting to make a hole in the front of my 02 to get cooling air to the radiator.
I dont want the ribbed original look. thats to easy to do.
I want a AC cobra design (the lower)on the intake but i dont know how this would look on a bug,or how to design it.
Anyone done something similar, or have any pic`s of intakes?
Another alternative is go for a Funcup front spoiler and modify it for the 02.
Any opinions?
Vin
Check out my project pic`s!
http://www.v-dubs.no/haraune
Old December 10th 2005, 15:38
Rob's Avatar
Rob Rob is offline
Not sure exactly what you mean, but I can show you what 'just a hole' looks like
Rob.
Old December 10th 2005, 16:05
That`s a hole yeah.
I want something that follows the lines and shape of the car a little better.
Radiused edges and smooth shape.
Old December 10th 2005, 16:41
I'm just going to cut a number plate sized hole with large radii, then black mesh so it will not be at all noticable with the dark paint. What colour is your car going to be?
Old December 10th 2005, 19:46
Originally Posted by Turbo Haraune
I want something that follows the lines and shape of the car a little better. Radiused edges and smooth shape.
Like this??? It's available from Mid-America Motorworks
Kafer_Mike
Old December 11th 2005, 08:24
Car is going to be dark silver.
That picture is somthing in the right direction. but i also want the mesh to be about 3cm in from the front plate if you know what i meen. i dont want the sharp edges from just cutting the plate. want to bend the edges innwards kind off.
Old December 11th 2005, 08:26
this kind of thing:
http://bb.bbboy.net/vwengineconversi...um=8&thread=45
bether pics: http://www.bugaru.com/
Old December 11th 2005, 08:34
somthing like the lower intake on this:
http://www.xs4all.nl/~luukb/cobra51.jpg
Old December 13th 2005, 20:44
Just what i would do...
1. cut the hole i like
2. transfer the pattern of the hole onto a cardboard (tricky part)
3. make a "tube" of the shape of the hole and weld it at the back of the front apron...
I know its a lot tricky to match the curve of the apron, but i believe its worth it. also first mark the hole, then cut about an inch or less (hole smaller than the sketch) so you will be able to make some relief cuts and bend the extra metal inwards to support the "tube"
or use the apron noted by kafer mike and make a "tube"
Chris
Aircooled 4ever
1973 1303 going towards GL
