Old November 15th 2002, 19:17
havik180 havik180 is offline
Lightbulb aftermarket oil cooler mounting
I am curious where oil coolers (w/elec. fans) can be mounted safely on a super's chassis while still being beneficial to the cooling process ?! I've noticed a lot have been mounted on the under side of the parcel tray , are there any clearence issues ? and also is there some kinda bracket to leave a slight gap between the body and the cooler (to let air flow between cooler and body) ?
Old November 15th 2002, 20:00
VW911 VW911 is offline
You should not have any problem if you are buying one of those coolers you see in the mags. Clearance should not be a problem.
To get the gap you need between the undercarriage and the mounting surface, get 4 vw rabbit radiator rubber bushings. They will give you the space you need and also absorb the vibrations.
http://community.webtv.net/vw911/VWGermanLookPage/
Old November 17th 2002, 00:30
Pillow's Avatar
Pillow Pillow is offline
You can make your own if you are creative enough.
Personally I think a fan is overkill in most cases for the street at least.
Try a Volvo or RX-7 cooler. Maybe even a remote Audi 5000 oil cooler (doghouse)
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old November 20th 2002, 05:29
Oliver Knuf's Avatar
Try a fan cooler from Mesa with a good fan. CB sells them for example. Use the mentioned rubber mounts but mount it also in the curve of the rear trunk metal, left over the gearbox in drivers position!
Click here to mail me!
Old November 20th 2002, 14:55
Pillow's Avatar
A problem with some of the fan kits is the ID of the cooler is 3/8" which is crap.
The VW should have at least 1/2" ID cooler and a 30mm oil pump to push the additional oil.
Check this out:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1873095188
Also the Volvo coolers are GREAT! For a mildish engine like 1776. Maybe a low compression 1914. I have pics, but too large to clip on. I have one boxed ready to ship for $20 + shipping cost.
This is cool:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1872997263
Adrian Pillow
Old November 20th 2002, 15:49
hey adrian, i bought the one for my 1600. think it is too small for the 2.0l TIV?
Old November 20th 2002, 16:46
Pillow's Avatar
Hey Zen,
If you are keeping the T4 cooler in lets say a DTM conversion you will hardly need any addtional cooling so I think the Volvo cooler would be good security mounted above the tranny with a thermoswitch on it. Maybe a sandwitch remote filter adapter right above the oil filter to the cooler.
I have been really impressed with the Volvo coolers. The 1/2" ID gives it amazing flow characteristics.
We need to get together anyway and I will show you how I would set the system up
Take Care,
Adrian Pillow
Old November 21st 2002, 17:52
Hello-
The position that you mount the cooler in can have a DRASTIC effect on how well it performs!
Obviously, the best place is up in front, but it's also the most difficult and expensive to fab up.
The most common is horizontally atop the tranny. IMHO, this is also the second-worst place to mount it (the worst being in the engine bay itself). The big problem is that the air that cools the cooler isn't really forced out of the cavity up there, so it can circle around and around, blowing hot air over the cooler.
For a good bang-for-buck location, mount it vertically to the side of the tranny. Air passing through the cooler will be directed away from it by the natural movement of the car. Use a good Mesa-style cooler and a fan (the fan DOES make a big difference... I recently had mine stall and I could tell!). The hardest part of this installation is the mounting - things are very tight back there. Be sure to avoid the CV boots, the clutch cable and bowden tube, and the trailing arm. But, once installed, it gets excellent airflow. Plus, unlike the over-the-tranny installation, the heated air is transmitted away from the cooler by the natural movement of the car. My testing has found this to be a HUGE benefit.
Take care,
Shad Laws
Old November 21st 2002, 18:34
57mutant's Avatar
57mutant 57mutant is offline
Shad
I have two of the slim line oil coolers and fans that CB Perf. sells. I was going to mount them horizontally above the tranny. When the time comes I'll look into your vertical position. Couple of questions on that set up. I assume you hang them parallel to the tranny. Do you have the fans on the inside (tranny side) or outside (wheel side) of the coolers? Any other tips on this installation? Thanks
57 mutant
57 Oval GL
Old November 21st 2002, 22:56
Hello-
No. I guess I didn't explain that very well... sorry.
The cooler is perpendicular to the tranny, i.e. it's parallel to the halfshaft. Lotsa airflow :-).
Cooling fans are typically best as pullers, not pushers, so it goes on the rear side of the cooler. Plus, this will keep most of the debris from hitting the fan.
Take care,
Shad Laws
Old November 22nd 2002, 00:19
Pillow's Avatar
Shad, good to see you here sir!
My concerns with a lot of the fan cooler kits it the ID is 3/8" and not a true 1/2". So just be careful when selecting the kit.
I like Shad's mounting idea... I have to mock it up to see how to hang it though.
Take Care,
Adrian Pillow
Old November 22nd 2002, 04:51
Hello-
Why thank ya! :-)
Or, just buy the pieces seperately...
Mesa/PermaCool/Long oil coolers are an excellent buy for the buck, and are available from many sources in the states for somewhat cheap. Of course, brands like Setrab are slightly superior, but unfortunately the price reflects it, too... (are they any cheaper in Europe???)
[BI like Shad's mounting idea... I have to mock it up to see how to hang it though.[/B]
Just watch the trailing arm... trust me... :-(.
Take Care,
Shad Laws
Old November 22nd 2002, 21:46
Shad, do you have a pic of how you're talking about mountig the cooler ?!
Old November 23rd 2002, 00:48
danielzink's Avatar
I think ("think") this is what Shad is trying to convey.
here's a pic of "one" of my oil coolers - I have another mounted an the opposite side of the trans -both with thermostatically controlled fans.
http://www.geocities.com/danielzink/cooler.JPG
Dan
Just highlight/copy and paste the above into your browser.
65 notch 2300cc type4
www.danielzink.com
Old November 23rd 2002, 05:30
Hello-
No, that's still horizontal. My setup is vertical, and approximately fits into a transverse-vertical (i.e. perpendicular to longitudinal) plane of the car.
I don't have a good picture... Maybe I should get one of my dirty car... :-)
BTW, haven't talked to ya in awhile, Dan. How are ya?
Take care,
Shad Laws
