Old December 20th 2005, 10:37
mullhollandGL mullhollandGL is offline
fitting air con
hello has anyone fitted the air con compressor to the t4 engines with the porsche fan shroud?
Old December 20th 2005, 21:33
I haven't seen one an a 911 shroud. Not that it can't be done. I know you can with a DTM.
Old December 21st 2005, 13:12
hi what do you mean not that it can't be done?u mean it is possible?
Old December 21st 2005, 14:48
Panelfantastic's Avatar
Definately yes, can be done. No kits are available. You would have to make all the brackets or stands to support the compressor.
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old December 22nd 2005, 11:02
what panel side. anything can be done with enough time. money and/or skills. don't let the lack of a kit stop you. if that is a serious issue though and a/c is a must, you need to look into the DTM and lose the 911 shroud (and get better cooling as a result).
Old December 23rd 2005, 00:05
alright!thanks alot for the advice!
Old December 25th 2005, 16:54
SuperRSi's Avatar
SuperRSi SuperRSi is offline
It can be done, but not easily. I started work on designing the mounts but as time moved on, I moved on to a STI motor for my bug and put the T4 in my Manx. I was going to use a rotary compressor and it was not a fit issue, but a mount issue. If you need help, let me know and I will try to brainstorm again on this end. I have the FAT shroud on my T4.
Randy
Old December 28th 2005, 11:33
something that i heared last week and didnt know... The MMC Smart car uses an electrical compressor for its ac system due to the very small engine...
Im going to try and find more info on that issue for my 1303GL (luxury cruiser...someday)
Chris
Aircooled 4ever
1973 1303 going towards GL
