Old December 25th 2005, 16:57
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Sandeep help please...
Hey Sandeep,
I need you to measure from the block to your BAS exhaust so I can see if the Autocraft drysump will work without mods. Thanks in advance.
Randy
Old December 25th 2005, 18:00
yetibone's Avatar
yetibone yetibone is offline
Mine's 65mm, or about 2.5" from the opening in the case for the oil pump housing, to the no. 2 headpipe. That's with the S/S header, NOT the Kafer Cup system the used to have listed.
Hope this helps.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old December 27th 2005, 10:56
Massive Type IV's Avatar
All the BAS systems vary a bit... Ask Zen!
Jake Raby
