Old January 6th 2006, 11:03
COXBOW COXBOW is offline
Talking Fit one piece sport seats ?!
Hi folks,
I’ve purchased some one piece sport seats to give that sporty look to my Bug, the problem is I don’t have sub-frames to install those !
I’ve found some in a aftermarket accessory shop, but they are all to low and worse, they don’t tilt forward !
I would like to be able to take some girls for a back-seat ride once a and while ;-)
Serge
Old January 6th 2006, 14:47
Normaly aftermarket makes (ie sparco, momo, etc) offer tilting subframes for the co driver side and sliding for the driver... but at an extra cost.
Bear in mind that it will be better to modify the stock seat base. Meaning keep the bottom part (sliding) and make a subframe(welded on the stock sliding mechanism) to mount the seats on top. Do a search here and you will find adequate info on this subject. Also try to fit a tilting mechanism from another make (if the bolt pattern matches)
Chris
Aircooled 4ever
1973 1303 going towards GL
