Old January 22nd 2006, 12:52
63 Bug 63 Bug is offline
8" wide wheels on a '63 bug?
Hi,
Ive recently fitted a 944 turbo brake set up to the back of my short axle, stock winged 63 bug. Question is, can I get away with 8" wide rear wheels and if so what mods need to be done to get them under the stock wings and what tyre size is recommended?
Wheels are 16" x 8" x ET52. What spacer size do I need etc??
Cheers!!
Old January 23rd 2006, 03:16
LLVWGL LLVWGL is offline
you might be able to clear with a short axle trans., but i think you would run into problems with clearance on the spring plates and bump stops
