Old February 6th 2006, 23:56
flat flat is offline
New Narrow beams
I'm proud to announce the new beams I'm making. The beams use strong one piece drawn over mandrel steel tubing, with steel uprights. The beams are fully jig welded on CNC machined fixtures to insure exacting tolerances. Why mess around with 'cut and shut' stock beams when you can have a brand new beam for a competitive price.
Beams are supplied with adjusters installed, and can be manufactured in any width you wish (wider or narrower than stock). Urethane bushings are installed for long life. The beam has proper body mounts and a steering stabilizer mount all threaded for stock VW metric bolts. A drill jig is included with each beam to allow you to drill and narrow your torsion springs with common hand tools. As an added bonus, the beam is about 25% lighter than stock.
Priced at $C385 (For 4" narrow LP beam , as pictured). Includes complete beam with adjusters and urethane bushings, finished in a durable wrinkle finish.
http://www.vdubengineering.com/products/narrowbeams.htm
Old February 7th 2006, 08:43
You guys are sure doing some dynamite work for our hobby.
