Old February 10th 2006, 03:47
75superAVW 75superAVW is offline
looking to rewire and came across this
I was redoing my dash and became dicusted with the birds nest of wiring behind it so i started looking around and i came across this http://www.hotrodwires.com/18Circuit.html . I was just wondering if this harness would work.
Old February 11th 2006, 07:47
70Ghia 70Ghia is offline
Go with the Wilson Street Works one, they have one for the VW. Easy to use too.
Old February 11th 2006, 15:02
Sorry to correct you 70Ghia, but its Watson's Streetworks. I used thier Vw system on my Father-in-law's '79 SB vert resto. To clean up under the dash i put the fuse box under the rear seat . This is a very friendly kit for the wiring impaired, but any of the streetrod kits will work too.
Here's the web site '75;
www.watsons-streetworks.com
Old February 12th 2006, 07:53
Red face
Your right,
I had a brain fart on that one.
Old February 12th 2006, 09:09
Im sticking with stock wiring on my 1303, does the wiring wear out and the VW wire colour system is very logical. Im planning to move the fuse box under front bonnet and Im going to use an 18 fuse box from a local Holden Camira, they are some sort of Vauxhal or Opel OS.
Old February 13th 2006, 04:08
i dont know abuot your wiring but mine is on its last leg. its very brittle and worn
