Old February 28th 2006, 03:13
speedy's Avatar
speedy speedy is offline
turbo ignition
i am running a turbo setup with conventional ignition(mallory dizzy), i was talking to a guy the other day who said you could get a vaccum turbo distributer , that will retard the timing back on boost (conventional vac dizzys work the opposite) any ideas if such a thing exsists and if so where do i get one ?
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old February 28th 2006, 20:14
Jeza Jeza is offline
Early turbo OEM cars use to use this sort of system, eg Subaru Leone. Others on here have mentioned Saabs and metros?.
You may be able to modify a dissy from one of these to work with a VW, or pehaps just use the vaccum can to work the VW dissy advance retard.
The other option is to track down a late model VW dissy, as they had an advance retard type vaccum can on them for smog control.
Hugh MacInnes mentions a couple of these style solutions to retard the ignition in his Turbo book.
It would be worth seeing if you can work out how much retard you chosen dissy has before you fit it up though.
Cheers
Jeremy
1302 RAt "GermanLook"
