Old March 3rd 2006, 14:21
Evil Sid Evil Sid is offline
8" rears question
I have access to a pair of 8x17" ET52 Porsche Cup II alloys. I would like to fit them to the rear of my late 1303 beetle (planning to lower it 50mm). The questions I have are -
will they fit at all without too much unreversible modification? (I *really* do not want wider fenders/wings)
and if they will fit what is the best brake conversion I should do to the rears so I don't have to run spacers?
many thanks
Old March 3rd 2006, 17:56
Using the search function should provide you with abundant information regarding your question.
Old March 6th 2006, 08:15
Dasdubber's Avatar
I have no idea of the space you have to work with on the 1303 as I've never owned one. I run 17x7.5 ET 52 Cup 3 replicas on swing axle (short axles) with CB performance rotohub discs. You can see the problem - and the bolt surface wasn't even close to seating on the disc surface.
I ended up having to run 35mm spacers (that bolt to the hub, then studs for the wheels - all approved by the certifying engineer) to get the wheels away from spring plates (but still under stock fenders).
And finally finished...
hope this helps just a little maybe. but yes the search function will help.
Old March 7th 2006, 05:19
May I ask what tyre size you're running?
Thanks greatly for the info and pics. I have searched extensively, and there are several comments about 7.5" wheels fitting and 9" wheels requiring wider fenders of the order of 1-2" but there are no comments around 8" wheels that I could find for a 1303. My problem is really once I get them I have no choice but to keep the wheels.
Old March 7th 2006, 06:02
nbturbo's Avatar
nbturbo nbturbo is offline
A work of art Alan.You could have run the longer Type3 axles and tubes and done away with the spacers.
Old March 7th 2006, 09:39
1303mark 1303mark is offline
my 1303 is currently being fitted up with 17, 9,55 porsche wheels.
running a cb performance rear disc setup, with 65mm ish wider wings.
i am using 15-20mm spacers, (still not decided yet as i dont have my final choice of tyres fitted yet)
with standard wings i think you will be very close.
you never will really know until you buy the discs, studs spacers and start trying to biuld it all together, using washers as spacers until you are sure.
i can easily fit a 225/45 tyre, but i am going ofr 255/40 later this week
Old March 8th 2006, 09:32
Dasdubber's Avatar
205/40 fronts and 215/45 rear - Falken FK451
Yeah Gary, before I got drawn into the german look, I was going to run 15x6in Porsche Fuchs with 205/65s so having the short axles would have worked out well....of course plans change, and rather than finding new axles and tubes and repainting, I decided to just go the spacer route. All is good in the end (just another AU$330 for the rear spacers - certainly learned a few costly mistakes during this resto!).
Evil Sid - as stated above, no matter how many calculations you make and people you ask, you'll never really know until you get it all bolted up. I got all mine bolted up and looked great (on front) until I realised turning circle was non existent - what do you know, more $ to narrow another front beam, then get another pair of spacers....such is life
Old March 9th 2006, 22:22
nbturbo's Avatar
"certainly learned a few costly mistakes during this resto!)." Tell me about it-I have enough new wheels,mudguards,body bits and pieces,sound systems,motors,transmissions etc. all discarded along the way as the plan kept changing.I had 2 X 5lt ice cream containers full of bolts,washers,brackets etc that I had zinc coated.Last week I spent a couple of hours sorting them into relevant areas of a Beetle and bagged them all together.I have enough bolts,wave washers and plates to bolt 3 Beetle bodies to floor pans.
Evil Sid- good info given to you here-but I went to VW shows and started asking questions and once you find a car with what you like-you can get all you need to know at the source.Good luck with your car.
Old March 9th 2006, 23:57
speedy's Avatar
speedy speedy is offline
i have some 8.5 et 50 wheels with 255 tyres and a 10mm spacer and they stivk out past the standard wings by 55 mm that is on irs with porsche brakes and arms
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 26th 2006, 03:20
OK,
To answer my own question I have temporarily fitted up my 8x17 ET52 wheels on the std rear drums on my Super. I have used Empi 25mm hub adapters.
With the car on std height the wheels look like they protrude by about 8mm max, but I guess when it's lowered at the rear it won't look like that anymore
I have used 215/45R17 tyres and they clear the bumpstop perch by around 10mm and also clear the outer springplate bolt ok.
They actually look pretty good like this - quite aggressive.
I am fitting a pair of 235/45 R17s Dunlop SP9000 tyres on to see what they look like as I have the tyres lying around. I suspect they may also clear, as at the rim the tyre isn't much wider it's just that it doesn't taper in as much at the top.
Will also post up pics soon.
Old June 6th 2006, 10:38
Now fitted up with my 235/45R17 tyres they are still clearing the bumpstops by about 3-4mm.
Old June 6th 2006, 11:14
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Which vehicle are those 8" wheels from? I like the Cup IIs but didn't think the larger than 7's where available with such a deep offset!
How about a part number from the wheel:agree:
Old June 6th 2006, 14:58
Yes 7.5x17 ET52 and 8x17 ET52 are both genuine sizes. So is 8x17 ET30 believe it or not (stick out more than the 9x17 ET55s) - I have a pair of those too kind of by accident
I will have to take a wheel off to get the code but they have a 993. prefix. Will post up early next week with it
Old June 10th 2006, 08:53
bug-er's Avatar
bug-er bug-er is offline
I have a pair of 8 inch cup twos with a ET70, perfect to fit under stock arches if you have porsche brakes
Old June 11th 2006, 21:55
DORIGTT's Avatar
What good is that to me!
You're across the pond!
