Old March 5th 2006, 02:01
72YloSB 72YloSB is offline
Cleaning Engine
What's the best way to clean my 72 Super's engine of all it's dirt? Is it safe to to use engine cleaner and water? I don't see any holes for water to escape the engine compartment.
Old March 5th 2006, 05:56
Racelook's Avatar
Racelook Racelook is offline
If your not going to rip the engine apart. I would cover al the holes (maybe with covers for "riooleringspijpen" ) and clean it with an steamcleaner. So an big Karcher only than with warm water and soap.
Brakecleaner (remmenreiniger in dutch) and an teathbrush is also verry helpful.
Wiebrand
B-Extreme B-Tuning.....
Old March 5th 2006, 11:42
super vw super vw is offline
you could remmove the rear (rear is rear) engine tin to let the water and crud escape. It's fairly easy to remove... check out a repair manual if you have never done it.
You can use any detergent you like, just make sure its not going to harm the paint or the aluminum (some acid based cleaners can corrode things).
A controled stream of water works best for me. you could use high pressure... but be carfull! you could end up taking more off than you planed. i like garden hose pressure for the engine if its not to thick of a buildup.
Take care to cover all electonics (like the distributor...ect) aluminum foil works good for this, that way it wont hose off and you can see it easy.
Jonathan
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
