Got tranny!
I finally got my 915 tranny w/linkage and shifter w/ali base.
How did you mount the '87 turbo front brakes to your spindles? Did you modify the 944T hubs to fit your B/J spindles? How? Did you modify the spindle to mount the caliper, or did you make a bracket for that?
Did you just lift the entire rear trailing arm/spring plate/parking & service brake assembly from a 944T? '87 trailing arms should be the 72mm wider ones, right? |
There are several ways to do this. I had Lanner, at vdubengineering do it. He is set-up to do it easier than I am. He modified the hubs to accept VW bearings. The CB dropped spindles had to be modified to accept Lanner's caliper brackets also. Have pix of everything on and off car. (they are posted on here just search)
The rear is alot easier as the torsion bars, spring plates, and trailing arms bolt up fairly easy.(getting the 944 pivot bushings out of the arm's is fun ![]()
Where are the photos posted?
Here's one thread (not all pix's though)
http://www.germanlook.com/Forums/showthread.php?t=7141 Click search and go to advanced section. Search by user name (wrenchnride247) and pic brakes, or suspension section... you will find some. ![]()
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
