Old April 3rd 2006, 08:21
mini_kris mini_kris is offline
wasserboxer?
is any one using a a vw wasser boxer engine in there bugs?
74 german look project
Old April 9th 2006, 13:28
Moog's Avatar
Moog Moog is offline
What - like this? 2.1 Wasserboxer with Weber-Alpha throttle bodies & Emerald ECU...
(o\ /o) '73 GT Beetle with 2.1 WBX (owned since 1990)
(o\ /o) '74 Jeans Beetle (owned since 1986)
(o\ /o) '67 Zenith Blue Beetle (needs lots of work..)
'02 Passat Sport Diseasel Estate ("Das Boot")
'05 Seat Leon FR, chipped (Mrs Moog's toy really...)
Old April 9th 2006, 17:33
Bad bug's Avatar
Bad bug Bad bug is offline
Moog how does it drive, is it fast, and do you get good gas milage.
Old April 10th 2006, 03:48
Looking good Moog!
Is it runnig yet? do you have some more pics, inc cooling setup?
Cheers, Rich
Old April 10th 2006, 04:01
Very nice.
I like it waaaaay better than any subaru or alfa engine
Old April 10th 2006, 14:42
Moog's Avatar
Don't know how well it drives on the road yet - it's still not quite finished & road legal. But it already wants to go! Shouldn't be that far off finished - i spent yesterday putting in what i hope are the last wires (shift light, fan operation light) and making up the handbrake cables for the rear discs.
Radiator is in wheel arch behind wheel - first pic is before shielding was in place, second pic is with shielding, which scoops air up as well to ensure it gets good air.
Radiator is a one-off in Ally by Pace products to my design, and is a work of art! I didn't put it up front as I had already done the front end by the time i decided to go WBX route. The fan is controlled by the ECU as well.
Will post up more pics later if y'all want?
Moog
Old April 10th 2006, 15:55
Moog's Avatar
Some more pics for y'all...
Some more pics for you...
It's taken far too long to get to this stage - i wanted it finshed for my Wedding - it was my fifth wedding anniversary 2 weeks ago...
Moog
Old April 10th 2006, 21:26
Moog thats nice looking conversion.
I did one in 1988, started off with 46 IDAs then I went EFI with a turbo. Now Ive sold all that and Im going 2.0 STI.
With IDAs
With turbo
Old April 11th 2006, 00:13
Bad bug's Avatar
Steve c you had a really nice car. Now that you have modified your chassis to accept the g50 gearbox i think you also weakened the chassis. If i was to go water cooled it would be a wasser engine.
Old April 11th 2006, 03:45
It's a long way from finished and I will be surprised if it isn't a lot stiffer when Steve's finished!
Great pics Moog, very nice quality work but I'd still cut up the front for a rad Do you plan to stay swing axle?
Old April 11th 2006, 05:05
The 1302 I used to own had a very hard life, mainly from me and it started to crack the body.
I still have to do more chassis stiffening to do on the 1303. I’m sure it will stronger than before when its finished. When I get a little further along I will start up a topic for the conversion I’m doing.
Wasserboxers are great motors, I had very little trouble with mine, only the odd water pump or coolant hose letting go. But a WRX Subaru is a 21st century Wasserboxer with lots of aftermarket goodies available.
Old April 11th 2006, 09:51
Moog's Avatar
Thanks for the comments Rich (& everyone else!) For the moment i'm working on the idea that i can do a mirror image rad in the other rear arch if necessary. It's only going to be 120-130bhp anyway, so not massive amounts of power. Pace products used a 4-core for the rad and reckon it will work in a marginal air-flow loaction - i take their judgment on that as i'm not a radiator designer (Just an engine designer trained by Ricardo - i think Rich will have heard of them ) Didn't your first Speedster Alfa engine run cool with just two mini radiators tucked up in the back?
I have kept it swing-axle on the Basis that it is a GT beetle - for those who don't know (those outside of UK?) the GT beetle was a limited edition spec, and the only time they used the 1600 engine & unique ratios in a swing-axle / 1300 shell in the UK. Only 2500 made, & only 10% this colour, so part of my plan was to keep many of the original GT features, and that includes sticking to the high-ratio swing-axle box. Basically, i'm trying to create a 21st Century GT Beetle.
SteveC - Loved your car - would like to have seen it for real! It was part of the inspiration for this engine conversion.
Cheers
Moog
Old April 12th 2006, 04:16
Fair enough, if you are only sticking to a low power I think you'll be fine, especially with your scoop. My speedster ran fine with the Alfa engine and twin mini rads and no ducting, so I think you should be OK. Must have been a very expensive rad, when I first saw it I thought you had got a deal on a single seater side mounted one as it looks very familiar!
PS I live down the road from the Ricardo MTC so feel free to give me a shout if you are up this way!
Old April 12th 2006, 13:39
oooooo, are they hard work to put in, am lookign at all the diffrent options for my 74 as the stock 1300 is giving up a bit
Old April 12th 2006, 13:55
Moog's Avatar
Sure, it's easy...
Change the 228 flywheel to a 215mm T4 (or 210mm or 200mm T4) and it bolts straight up to the gearbox - easy. The hard part is then working out how you are going to do the cooling system, and what carbs / injection to use - my 40 Weber-Alpha throttle bodies are on Wasserboxer IDF manifolds with the tops cut & rewelded & re-tapped to turn the throttle bodies around and fit the DHLA pattern. Fuel injection requires High pressure fuel pumps as well as a low pressure system, plus returns into the fuel tank. LOTS of wiring for the ECU. Throttle linkage is a much butchered T1 pull-style. Stock starter struggled to turn over the 10.5 compression engine, so that is now new. Etc, etc, etc...
Just work through it methodically and you'll get there. But you do need patience and to think laterally at times.
Expensive part for me was the custom made radiator in ally - £400...
