Old April 6th 2006, 14:25
VEEMAN VEEMAN is offline
Is there any pieces missing from the strut top mount
Can someone have a look at the attached picture of how the top strut mount is laid out to fit it back together.
1. Purple spring cup.
2. bearing.
3. top body mount.
4. concave plate.
5. lock nut and washer.
So is there any bits missing for this assembly?
When I tried to put it together there was a gap between the purple cup and the top mount cup itself. It seems that the bearing is holding it apart. My concern is this purple spring cup will shatter if it has got no support behind it.
So if anyone has fitted Kerscher 2 bolt struts, from an 3 bolt early type please have a look and put me right .
Ceers
Veeman
Old April 6th 2006, 14:36
Sorry did not post picture first time
2. bearing.
3. top body mount.
4. concave plate.
Ceers
Veeman
Old April 18th 2006, 16:06
G-force G-force is offline
Here's a nice diagram of the early strut:
http://www.schmiddy.de/vw1302ig/p03/vaxl02.jpg
Old April 19th 2006, 19:26
73 sportsbug's Avatar
73 sportsbug 73 sportsbug is offline
just got my kerscher struts yesterday and will be assembling for mock-up within the next few days, two-bolt for the 944 spindles going on a '73.
i'll get a pic as soon as possible when i do. i was wondering about the synthetic spring perches when they arrived, but i don't believe they would be so weak as to "shatter", coming from a company with kerscher's reputation.
rusticus maximus
Old April 21st 2006, 18:46
just got them mounted last night
veeman, do you have the spacer (number 17 on g-force's exploded view)
i didn't have any problems, except mauling the driver side spring with my
chi-com spring compressor. let us know how it goes.
rusticus maximus
Old August 19th 2006, 17:16
davey1302s's Avatar
davey1302s davey1302s is offline
kerscher
sportsbug/Veeman i am going to change my struts for kerschers, so what parts from the old set up did you use when fitting the kerschers? was it only item 17 from G force post of old damper, what about the bump stop item number 20
cheers
