Old April 12th 2006, 08:58
kuna's Avatar
kuna kuna is offline
97' Passat inner handles in 1303
Yesterday I bought inner door handles from VW Passat, the handle itself works and fits great in beetle, problem occured when I've tried to connect power window switch, it has only 4 pins (previously I used ford 6 pin switch, pair for window motor, pair for light (+/-) and pair for power (+/-))
does anybody know how to connect them to standart 2 pin (SPAL deluxe) window motors? any sugestions?
Anybody have any expirience with modern VW/skoda/seat power window switches? some schemes? diagrams?
Thanks for hlep.
Old April 16th 2006, 16:30
kuna's Avatar
... :( it can't be done
to all thosoe who would like to use VW swithes. They only can be used with VW window motors and VW comfort computer. Ford ecsort/mondeo/scorpio swithes work fine and can be fitted into VW handles (with some modification of course)
regards.
Old September 20th 2006, 18:38
Angelo Amato's Avatar
handles
hi, got any pics fitted to car ? how did you mount handle ??
cheers, angelo
Type 3 Fastback
Old September 21st 2006, 03:44
might be a bit awkward using those, on my passat the window switch is like that on the passenger side but down lower in the door in a multiswitch plate on the driver's side. Maybe different for different models?
Old September 21st 2006, 06:45
kuna's Avatar
there you go.
Photos with handles installed. I had to make special adapters from fiberglass (2kg of plaster to create mould, and two layers of fibreglass - realy easy task, I thought that making f/g parts is more difficult) to hide electric window motor assembly as I'm using one piece windows. Door panels and my f/g adapters are covered with self-adhesive material used for making car audio boxes. If you have any questions feel free to ask.
BTW: Handles are from back door of 97' VW Passat/Bora
Old September 21st 2006, 16:19
nicely done! i like the look. if you care to write a technical article on it, let me know and i will get you access.
Old January 16th 2008, 16:51
66sandrail
is the window winding mechanism the same with the stock two peace one or?
and how about the window ruber what did u use ?
