Old April 13th 2006, 02:45
1303mark 1303mark is offline
rear wheel spacers, 5mm wider on one side, is this safe
did another fit on my wheels last night,
with 25mm spacers on the rears, one side is clear one side fouls,
so i stick an extra 5mm on the foul side and it is now fine.
problem is can you safely run with 25mm spacers on one side and 30mm on the other, personally i dont see any immediate problems, but then I am probably too close the the project,
i could try an extra 5mmn on both sides, but i might foul the good fitting wheel,
any thoughts
Old April 13th 2006, 04:18
The question of its safety wouldn't be 25/30 being safe or not. It would be why you needed 25/30 in the first place. If the answer to that is inconsequential, you should be okay.
I do hope your spacers are hubcentric, though.
Old April 13th 2006, 04:38
speedy's Avatar
speedy speedy is offline
running with different spacers is fine i run 20mmand 30mm on the back, i was talking to eddy remmele about this and he said it is normal when going to wider tires to need slightly different offsets,he said he has put wider wheels on bmw's where the axle has been out to the bodywork , on beetles the body is bolted onto the pan so some discrepancy to the bodywork is normal , i was talking to a garage about this and he said the tolerance on a vauxhall nova back axle is up to 10mm from the factory!!!
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old April 13th 2006, 06:10
thanks for the reply guys,
the clearance issus is wheel to spring plate on a 1303, one side is 5mm closer than the other, this could be due to tracking adjustment not being set yet.
that deals with the why,
so running with different spacers is ok.,
i will proceed to make some 6mm spacers, out of plate and pull the washers out that i have been using.
as for hubcentric, they aint, co sthey are on the rear with CB perf rear disc setup, there is no lip to locate a spacer or wheel off for that matter, very similar to the stock arrangment where the bolts pull the wheel in centerally.
