Old May 7th 2006, 06:32
tom'72's Avatar
tom'72 tom'72 is offline
CNC pedals anyone?
I can buy this CNC pedal set locally for only 150 Euro's
Does anyone have this setup in their bug and can you give some feedback on it please?
I plan on putting it in when I change to a hydrolic clutch.
Old May 8th 2006, 04:21
If you want the pedals in the stock position it looks like you will have to modify the bulkhead so the cylinders sit forwards of the bulkhead and the throttle pedal matches up.
Make sure you can fit a dual circuit m/c for your brakes, I never did understand why these came with single circuit! Mark Thurston used one of these I think and was able to fit a Porsche brake m/c with some tweaking
