Old May 11th 2006, 21:28
73 sportsbug's Avatar
73 sportsbug 73 sportsbug is offline
has anyone seen or done a narrowed super front susp?
and i mean moving the strut towers, not just using <73 components with 74 and up struts. i'm about to do this and was wondering if there's anything out there already. (yes, i'm serious)
rusticus maximus
Old May 11th 2006, 22:21
This car had it done, they used late model struts and control arms as the arms are easily cut & shut.
Old May 12th 2006, 12:30
75_1303 75_1303 is offline
Steve C, what kind of mirrors are those?
Old May 13th 2006, 05:10
Im not sure, I will try to find out.
Old May 13th 2006, 16:19
thanks for the reply steve. do you have any pics inside the trunk of the strut towers?
charlie
rusticus maximus
Old May 15th 2006, 01:55
I will try to get some picturs for you.
Old May 28th 2006, 23:02
This is a scan from a magazine article. I havent been able to catch up with the owner.
Old May 28th 2006, 23:27
VWader04's Avatar
VWader04 VWader04 is offline
Mirrors- they almost look like Vitaloni California's...but can't tell for sure.
Old May 28th 2006, 23:30
VWader04's Avatar
I can't tell by the photos...the strut tower looks stock...did you say he modified it??
Old May 29th 2006, 00:03
The towers were elongated so that the strut tops could be moved in.
Old May 30th 2006, 20:39
thanks again steve.
that's what i'm hoping to be able to do, just toward the top of the strut tower
but with a two inch per side narrow, i may have to bring in the lower part where it meets the trunk floor(even with the skinny kerscher struts)
i've already cut out some doner towers from a '74, so i may just maul mine and insert the others(either way it's going to take a while to drill out all the spot-welds on one or the other)
charlie
rusticus maximus
Old May 30th 2006, 22:03
I saw a really old VW mag once and they showed how to lower a super beetle buy cuttung and moving the whole strut tower, when you weld your new one in might be able to weld it in a bit higher.
Old June 1st 2006, 20:44
the ride height will fall under the strut's duties, my problem is that i want fuchs wheels and they don't have a large offset like the later model porche wheels. so in order to keep from widening the front fenders(i think the super looks kinda "narrow-assed" anyway) i need to narrow the suspension. whatever i do, i want it to look "factory", so i'm not going to use a lot of alien looking material, hence the donor strut towers. nonetheless, thanks for the replies. i was just hoping to get some ideas if anyone had done it before.
charlie
rusticus maximus
Old June 13th 2006, 21:38
Jeza Jeza is offline
Hello
Sorry I saw this a while ago and forgot to reply.
I've fitted the early 944 brakes to my 1302 and use cookies (early offset) under standard guards.
I've got some photos here
http://carolineandjeremy.multiply.com/photos/album/2
Effectively I cut 25mm out of the 1303 arm and boxed it in, then i used a 1302 swaybar, which is narrower. I also used a spherical ball top strut mount and small diameter coil spring to bring the struts inwards.
Unfortunately I stuffed my measurements up a little so I don't have as much camber on the front as I'd like (1 degree max, even with the topline camber plus kit).
What I'd recommend is getting the camber plus kit, moving your strut tops inward as far as possible and seeing if you can get away without cutting the lower arms - just use the camber plus kit to bring them in-board a little.
What hubs are you using? The 944 ones have more positive camber than the beetle ones so watch out for this.
Good luck.
Cheers
Jeremy
1302 RAt "GermanLook"
Old June 14th 2006, 18:24
thanks jeremy. i've already narrowed a set of 1303 track arms and mounted them up with a 1302 swaybar like you did (but i did 3/4" inboard and 1 1/4" from the sway bar mount to ball joint area, 2" total per side) i've got 944 spindles and right now it's looks like the back end of a swing axle without an engine \ /
rusticus maximus
