Old May 12th 2006, 11:48
Mexibeetle Mexibeetle is offline
17" wheel fit on standard Beetle with 18mm Adapters
OK, I have read through just about everything here on whell fitment but seems that everyone either is doing this on a Super or has a norrowed front end. Also I see comments about ET 40 fitting perfectly and ET 50 or ET55 Porsche wheels fitting. This doesn't make sense that bot ET40 and ET55 fit. I have a standard beetle ball joint front end with discs on fron and drums on back all stock. I have a 4X130 to 4X100 adapter from a 914 that is 18mm thick and am trying to find out what offset on a 17X7 would fit under stock fenders. I have spent hours researching but it seems everyone else has widened fender, narrowed front end or some other modifications. Any help would be appreciated.
Old May 12th 2006, 22:46
scottwebster's Avatar
scottwebster scottwebster is offline
I am not sure either... I have some 16X6 and 16X7 not sure of the ET but we can just try them on and see how they fit.
I am located in Sugar Land, TX (Hwy 6 and W. Airport)
I should be out in the garage most of the day tomorrow. Call me if you plan on coming over.
281.450.5800
Scott
Scott Webster, Houston TX
1979 1303 Convertible, 1966 GL Sedan
Old May 15th 2006, 16:09
GunnyOz's Avatar
GunnyOz GunnyOz is offline
17 In. Wheels
Mexibeetle
I'm having the same problem. I have a set of MaXX struts and was told to use
7in. 55mm (6 in backspace) offset wheels with them,VDUB customs who did my 5x100 TT hubs said 38-42mm will work. Another article I read said 40-45mm. I as lost as you are. Can anyone clear this mess up. I really don't want to end up with a jacked up Buggy.
GunnyOz
Old February 23rd 2007, 08:05
I just found this post while looking for something else, I hope its not to late to help you. I have a 73 1300 Bug, it has a stock balljoint front end in it. I'm running 6x15 Cookies, these have a 36ET and fit nice. So if you add your 18 + 36 you would need a 54 ET wheel in a 6 inch to fit nicely, in a 7 inch wheel you would need a 67 ET, something your unlikely to find. So I think you need to ditch the adaptors and get you drums or discs re drilled.
You can have a play around with wheel ET on this page http://www.1010tires.com/WheelOffsetCalculator.asp
Last edited by Steve C; February 23rd 2007 at 08:06. Reason: hyperlink not included
