Old May 15th 2006, 20:45
GL-Aussielooker's Avatar
GL-Aussielooker GL-Aussielooker is offline
GL Type 3 squareback pictures
Hello all:
:help: I am looking for any pictures of GL squarebacks. I have one and want to see what I can possibly do with one. Thanks :help:
70 RHD Beetle
67 11 window walk through
Super wanted
If it ain't steel, it ain't real
Old May 16th 2006, 17:19
zeroaxe zeroaxe is offline
Wish I can find that magazine of mine that had that Square in it. They went all out and spend big $$$ with Porsche brakes/suspension/motor etc etc.... I would consider THAT is a GL Square!
Old May 16th 2006, 17:22
trevorbrady's Avatar
Brian Burrows's squareback:
Old May 16th 2006, 18:29
Pillow's Avatar
Pillow Pillow is offline
Vujade had a Notch GL maybe he could chime in a little...?
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old May 16th 2006, 19:16
Wow that squareback is very GL.... nice. So I would be able to run the porsche brakes and rims and engien in a sqareback.
I saw a VW Touareg today. I like the dash set up. Will be photoshopping a pic of the dash in a sqareback to see how it looks. But I might just go with the pursche dash as well :idea:
70 RHD Beetle
Super wanted
Old May 17th 2006, 03:47
don't bet on it. That car has a full custom chassis with the squareback body set over the top. It's built for dragracing, not necessarily High-G cornering...
Old May 17th 2006, 09:50
Another question? I can lower the squareback like i did my beetle or is there more to it.
I adjusted the rear plates and added dropped spindles and an adjustable narrowed beam to the front of the beetle.
70 RHD Beetle
Super wanted
Old May 17th 2006, 11:29
the rear suspension of the type3 is the same as a similar year bug. The front axle can be lowered by adjusting the splines, in a similar fashion to the rear of a bug. Apparently it's very easy but I've never done it, maybe someone with a type3 can advise...
Old May 17th 2006, 15:25
That'll be the Square that I was referring to! That thing is wickedly tricked out... BIG $$$. But you can only go for looks, no?
Old May 17th 2006, 18:10
kitchenware's Avatar
kitchenware kitchenware is offline
Correct, first mark where it is, then just loosen the set screw/nut and pull the lower trailing arm in the front out/off the torsion bar and turn them a spline or three (up) and shove them back on, snug up the set screw/nut. Been a while since I've done one, but that should get you going on dropping a t3. Very easy to do.
Old May 17th 2006, 18:41
Thanks for the info. Sounds as easy as the beetle was to do.
70 RHD Beetle
Super wanted
Old May 22nd 2006, 18:09
Bogara_ZO's Avatar
so nice!! Have you got any other pics of that green bug in the background?
Old May 22nd 2006, 21:54
vwdmc16's Avatar
vwdmc16 vwdmc16 is offline
Hey you guys see that this Sq back is for sale on thesamba.com yeah they want like 38,000 pounds! or $56,000!!
Old May 23rd 2006, 01:37
Are there any more pics available of that Square? I'd like to check out the front suspension again.
Old May 23rd 2006, 06:28
Hebster52's Avatar
Hebster52 Hebster52 is offline
There you go!
993 Square for sale!!!!
