Old May 16th 2006, 12:22
GunnyOz's Avatar
GunnyOz GunnyOz is offline
I NEED 17in. Wheel Help
I ready to finish my 74 SB but I really need help with this wheel thing.
The wheels that I'd like to use are Motegi DV5's. They are 7in. wide with a
42ET and a site stated 5.625in. backspace. The front setup will be Maxx
struts with VDUB Customs front hubs.The hub set up is suppose to reduce
the track by 2mm per side. Is there a Pro out that can give me some help??
I don't want to slam the car and I'd really like to use the stock wings (money
for this phase of the project is tight) and ending up with a Jacked Up Baja
would kinda suck.
GunnyOz
Old May 24th 2006, 13:15
euro1302s's Avatar
euro1302s euro1302s is offline
hi there, don't know if you saw this but VDUB ENGINEERING has a kit suited for the type of application you need, have'nt use there product 'coz I'm form the Philippines but it's almost the same as what I'm using the only difference is we custom made my suspension, this is how I install my 17x7 Rota Toxxin with a +42 offset wrapped with 215/45R17.
http://www.vdubengineering.com/products/narrowcoil.htm
HOPE IT HELPS.
