Old May 21st 2006, 12:37
kai4130 kai4130 is offline
Type 3 break questions
Okay i've search this forum for days and I have a few questions.
Would I be right in thinking that I can buy a 944 front hub, spindle and break assembly and bolt it in place of my old type 3 assembly, with some modification to the tie rod hole (Something about resizing it). Or would that be to easy.
If not then, how can I go about sorting the hub. I'm not to keen on having my old disc machined down, as I will be running 15" porsche wheels.
Can I modify a porsche hub to fit to the VW spindle? If I go this route I presome that I will need a means of fitting the caliper to the hub assembly, how will i be able to overcome this.
I think that I will use either the original vw master cylinder, a mark one golf M/C, or go full on with the porsche M/C
back to the searching
Many thanks
Old May 21st 2006, 14:13
Mikey's Avatar
Mikey Mikey is offline
Check out this site. www.vdubengineering.com
Mike
'04 R32 Tornado Red
Old May 21st 2006, 16:49
O.K. so i'll possible look into buying the a kit.
I wonder how much it'll cost to send to England.
