Old May 24th 2006, 18:20
Panelfantastic's Avatar
Uhm... am I missing something?
These are $1100 plus shipping?
http://cgi.ebay.com/ebaymotors/VW-Be...spagenameZWDVW
Isn't that double what they should cost? Maybe I've got these pieces confused???? I realize there is a lot of bling/billet but the simple versions I've seen for like $200.
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old May 24th 2006, 21:10
That sounds too high for uni set-up . The machine work looks top notch though.
Old May 24th 2006, 22:38
Bullyboy Bullyboy is offline
Thats pretty pricey for a rear end held together with a single rod end uke:
Old May 24th 2006, 23:28
Pillow's Avatar
Pillow Pillow is offline
Seems much weaker than stock due to a single "bolt" acting as the spring plate!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old May 24th 2006, 23:44
VWader04's Avatar
VWader04 VWader04 is offline
there is no torsion bar...so you also need rear coilovers.
So that has to be figured in to your buying decision as well.
Old May 25th 2006, 09:59
volksdragon's Avatar
i dunno maybe it's made of gold. or maybe it wasn't machined but hand made with a file
Old May 25th 2006, 11:16
speedy's Avatar
speedy speedy is offline
that is probably about the right price if they have been cnc machined ,remmele and mbt charge about $1700 for the kit with coilovers ,go onto the remmele site and compare the quality
cheers jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 25th 2006, 16:49
kiwivw kiwivw is offline
This link is for the MBT CNC machined uniball setup.
Look at the seller's ID, it's Uwe himself (or someone claiming to be him)
Cheers
Craig.
Old May 25th 2006, 18:19
wow thats pricey.
but i do like the outer plate to add support. most of the heim joint kits don't have that
