Old June 3rd 2006, 14:44
DORIGTT's Avatar
DORIGTT DORIGTT is offline
How do I clean my dirty arms?
Hello all!
I just purchased a set of aluminum semi-trailing arms for my Ghia and they are DIRTY! What is the best method of cleaning them up so they look new...not polished?
Thanks Pillow for the arms..
Old June 3rd 2006, 22:57
A can of oven cleaner, or engine degreaser, wire brush, and the local car wash is the first step I took. If you have someone with a parts washer then that can do the same thing. Once all the "bulk dirt" is off you can use different types of wire wheels in a hand held drill to clean them up to the finish you want. If you want them to stay clean get some "rattle can" clear coat , and spray a coat or two on them (eastwood company makes a good clear called diamond clear that won't yellow). That way dirt can't stick as easy, and you can hose them off easier .
Old June 4th 2006, 09:46
that's pretty much what i did. degreaser and some elbow grease. (no pun intended)
Old June 4th 2006, 23:24
Bullyboy Bullyboy is offline
Sand or glass bead blasted they look new.
Before
After
Old June 5th 2006, 15:23
DORIGTT's Avatar
DAMN! Mine are definately the before shot.
Are you concerned about grit infiltrating the bearings during the blasting process? I noticed your hubs were still installed....
Old June 5th 2006, 15:45
If I wasn't disassembling them all the way down to the bare bones, I would have taped off the gap.
I am going to replace the bearings later, but I was tired of trying to fit things up and get dirty every time I handled them. I had to try out my recycled junk blast cabinet anyways.
