2366 T4 parts and CSP carbon porsche fan kit
All these parts are brand new apart from the crankcase
Type4 Crankcase, cut for 103mm cylinders and for johnson lifters. Johnson lifters and brass inserts, cut for porsche fan. all NEW from Custom Speed Parts in germany the product codes match their website for more info carbon fibre porsche style fanshroud NEW porsche alternator and fan and stainless strap198 240 400K and rear carbon 'tinwear' 119 524 400K T4 1.5Litre deep sump kit 115 181 415 new T4 oil pump stock 115 105 021A new T4 Eurorace 3 stage dry sump pump (the last new unused one in existence supposedly) Polished Billet oil filler neck and dipstick 115 359 000 Billet pulley 115 359 000 lightened 215mm flywheel 105 271 411 needle bearing for above 105 313 111A Billet oil cooler bypass 115 301 018 oil filter block off 115 359 000 T4 straight cut cam gear set 109 015 401 and 1800cc heads (not worked or cut yet) SECOND HAND and will need working to suit spare 1800 crankcase SECOND HAND AND NOT MACHINED Ideally you would offer a lump sum to take the lot as it will get progressivly harder to sell the parts bit by bit, you understand. so for the meantime who makes me an offer to buy the lot will get first dibs. note: the EURRACE dry sump oil pump is worth £600 alone so if you dont want that im prepared to split that item off £1800 the lot £1200 all except the EURORACE pump £600 for EURORACE pump jim +44 07815 288850 hillingdon Middlesex England UK |
