Old June 22nd 2006, 18:25
hugovw1976's Avatar
hugovw1976 hugovw1976 is offline
Another porject. 2332 cc. Type 1
This bug is a birthday present for my father.
The car:
VW 1976
Old June 22nd 2006, 18:28
hugovw1976's Avatar
Front brakes:
Rear brakes:
Before painting job:
VW 1976
Old June 22nd 2006, 18:29
hugovw1976's Avatar
After:
Wheels: (16" Phone Dial)
VW 1976
Old June 22nd 2006, 18:30
hugovw1976's Avatar
After some hours of work:
VW 1976
Old June 22nd 2006, 18:32
hugovw1976's Avatar
VW 1976
Old June 22nd 2006, 18:34
hugovw1976's Avatar
Aluminum Engine Case:
94 mm. Pistons:
VW 1976
Old June 22nd 2006, 18:36
chug_A_bug's Avatar
very very nice keep the pics coming.
72 Std
69 GL
hugovw1976's Avatar
84 mm Crank:
SCAT C95:
12 lbs :
VW 1976
Old June 22nd 2006, 18:37
hugovw1976's Avatar
1700 lbs :
More:
VW 1976
Old June 22nd 2006, 18:44
hugovw1976's Avatar
48 IDA Weber:
VW 1976
Old June 22nd 2006, 19:38
SoCalGL SoCalGL is offline
interior shots
hey in your interior shots u wrapped your door in aluminum insulation material what company stuff did you use ? have you used it before? and would you recommend it
thanks
Old June 26th 2006, 13:25
crickitobs crickitobs is offline
That looks hot! I'm jealous, I'd love a set of Teledials.
Old June 26th 2006, 14:48
hugovw1976's Avatar
thanks
I's the first time I don't have any experience with thath. i buy it on ebay
VW 1976
Old June 26th 2006, 22:12
aceracer24 aceracer24 is offline
I don't know what stuff he used on the doors but it looks very similar to what I used on mine. You can get it at a roofing store. It's basically sticky rubber tar with an aluminum backing on it. Sticks really well and molds to most shapes pretty easy to as you can see by his door panel. He might have the better IE more expensive stuff that has butyl in it. Thats expensive stuff compaired to what I used. The only real differance is the stuff with higher butyl will stick to things like roofs and side panels better especially in extreme heat area's.
Old June 27th 2006, 13:04
If he bought it on eBay, its most likely B-Quiet. I'm using their "Ultimate" SDM on my car. Excellent product and customer service -- and much cheaper than Dynamat... :agree: :agree:
Kafer_Mike
