Old June 22nd 2006, 18:52
adaptorman adaptorman is offline
Exclamation 71 beetle disc help??
as i had std solid discs on my balljoint bug i need some bugger ones to stop this lump ive fitted prob his i carnt find a hub that fits a bug shaft?(tryed 924 dont fit ?) i could do with a hub so i can mod my own disc set up can anyone help or know something what fits or i can use???(ill have to re drill/tap to volvo pcd if someone can help?
Old July 11th 2006, 11:55
flat flat is offline
Not exactly sure what you're looking for. You can re-machine your disks for the Volvo bolt pattern. Or you can machine down your disks to make hubs, then use the volvo rotor over that and machine a caliper bracket.
I haven't yet come across another car with the same bearings/spacing as a vw beetle.
www.vdubengineering.com
