Old June 30th 2006, 22:53
chug_A_bug's Avatar
Question window scoops
where can I find these on the web can't seem to get anything off google
Old July 1st 2006, 00:31
Are you talking about NACA ducts in the quarter windows? If so search NACA ducts.
Old July 1st 2006, 00:36
chug_A_bug's Avatar
Talking
thanks just order me a set puting in my lexan this weekend
Old July 5th 2006, 11:28
I wasn't sure these really worked, but I talked to a few guys at Bugorama who have them installed in their drag bug quarter windows. Most didn't have any idea whether it worked or not! But one guy said he'd bought his car complete from another guy. The builder had been very detailed oriented and had actually measured the pressure/vacuum in the airbox. The owner told me he recalls the NACA ducts created 3-5lbs of pressure in the box!
Old July 5th 2006, 21:27
chug_A_bug's Avatar
wow that's cool to know but you wouldn't know but summer days here in canada get hot so I need anything that can help. now what kinda hosing or piping should I be using?? thanks
Old September 7th 2006, 12:35
effvee effvee is offline
Naca Ducts
I fused mine
http://i86.photobucket.com/albums/k9...e/IMG_0003.jpg
http://i86.photobucket.com/albums/k9...e/IMG_0002.jpg
http://i86.photobucket.com/albums/k9...e/IMG_0004.jpg
Old September 8th 2006, 08:53
ajsyrup ajsyrup is offline
i was thinking of useing these on my 59 and running the air ducts to the old heater ducts that were under the rear seat to put more ait into the engine compartment for cooling. would this work or is it just a silly idea? also wasnt planning on running a shroud but instead 2 electric squirrel fans let me know what you guys think.
Old October 24th 2006, 20:58
THE FOLLOWING IS BASED ON THEORY AND MAY DIFFER IN PRACTICE. GOOD TO READ AND MAKE YOUR OWN CONCLUSIONS AS TO WHAT YOU WANT TO DO TO YOUR CAR. PERSONALLY I WILL BE USING THE FOLLOWING IDEAS TO EXPERIMENT WITH MY CAR AT A LATER STAGE.
While doing some reading for uni for my dissertation, i made the following conclusions (nothing really new but i have to justify everything...).
Theory 1
Quote" The incoming stream is slowed down by a short duct (diffuser), then passes throught the heat exchanger, and is ejected into a low-pressure area" (p.214 ISBN 0-8376-0142-8).
Conclusion 1
Any duct or opening that intakes air has to be on a high pressure area of the vehicle's surface.
This was written for a front mounted radiator ducting, but some of this applies to all ducting. The diffuser isnt needed so much if a radiator or heat exchanger isn't used, but from observing the rear wing inlets on a 996 turbo (intercooler mounted below the tail spoiler) reveals that the actual pipe's diameter is much smaller from this of the opening and that the pipe actually increases in diameter a bit further downstream.
This is done in order to slow the intake air and make it more smooth flowing before it goes further down
Conclusion 2
The rear quarter window surface on any beetle isnt the place with the highest pressure, simply because it isn't on the same plane as the rest of the side panels. IMO a NACA duct will not use all of its flow potenial if fitted on a rear quarter window.
A Remmele style scoop (position-wise will probably flow better), might be in a better situation but i haven't studied them at all.
Conclusion 3
If you don't provide a suitable exit for the air, there will be NO air coming in.
Its as simple as anything that goes in has to come out.
Assuming the application is an aircooled road beetle, there is no actual point in disturbing the factory engine bay air flow with extra intake if you cant provide the neccessary exits. Here comes the tricky bit.
Most of the race/ hipo guys here know that the beetle's back shape (hump) is a nightmare from an aerodynamic point of view. Best guess to seperate the flowing air from the hump is a small spoiler fitted above the rear window.
Ok, so u fitted the fancy bit. how about the air that has to come in from the vents in order to get into the fan shroud and cool your beloved "money pit" ( just to quote smbd here...)?
Lets assume that the above isnt affected. How can u extract the hot engine bay air? Get creative and dont think of poping your decklid, cause exhast fumes and hot air will come inside and kill your engine. You must provide some ducting to get the air out as well... IMO the best way to do this is the use of some vintage decklid with cresent vents sculptured into it (cant find the pic now...). The vents are high enough to get the LIGHT HOT air into the stream of the air coming from the sides of the car.
The better this is I believe that a cooler intake air will be observed, but if overdone air will be stealt from the fan's intake compromizing stock cooling.
As a result i would go for a flat bottom and NACA ducts placed after the torsion tubes and between the diagonal arm and the torsion plate, since there is enought air coming under the car's body. Then direct the air stream upwards through the rear parcel tray and throught the firewall. then some alu vents riveted on the firewall will direct the air downwards ( where cold air wants to be by nature) and provide the exit though a cut out part of the decklid under a specially made wing ( low-pressure area)
No SKETCES or DRAWINGS will be revealed for this as i might merchandise some of the products of the application so i would like to hold the copyrights for this. There are enough hints for this direction. The ISBN number stated above is from a really good and explanatory book for advanced Aerodynamics that can be bought for about $ 35US. NO offence.
Anyone who has the time and money may use this info and investigate more into this. The reason for doing this is that im looking forward to get into the beetle racing scheme when i finish my Automotive Engineering Designer Degree.
Chris
Aircooled 4ever
1973 1303 going towards GL
Old December 13th 2006, 23:32
martilo's Avatar
martilo martilo is offline
Here is how I resolved the issue for my bug. I haven't tried it yet, but i believe it will work as the scoop are located in a high pressure area (front of rear fender) compare with side window mounting. Anyway I don't think it a big deal as the NACA duct has a foil effect trapping side moving air.
Check my solution here:
http://www.germanlook.com/Forums/showthread.php?t=8207
Louis
Old December 19th 2006, 11:59
Hey Louis,
thats a really nice application. Good work. Im going similarly (design stage) with half of the scoop on the quarter panel and half on the fender in order to minimise alterations on the seat mounting. How strong is the seat bracket?
Chris
Aircooled 4ever
Old February 4th 2007, 06:48
1303R's Avatar
1303R 1303R is offline
anyone ever come accross these ducts in steel? i really like the idea of having em in the rear pannels but not sure if it would crack. if not then some sort of swaging around the duct would prob be best.
Old February 4th 2007, 13:08
chug_A_bug's Avatar
hey I haven't seen Steel ones but I know that Remmele has CF
ones or maybe Carbonjoe can help.
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old February 4th 2007, 15:27
1303R's Avatar
i'm just worried that cutting a hole in rear quarter and glueing on plastic is not gonna last long before it cracks. thinking that a swaged edge on the steel would help. thou cant seam to find the tool at the mo
Old February 5th 2007, 13:05
chug_A_bug's Avatar
heyhey well I'm really sure that a set of CF scoops will not Crack is the guys at Remmele use them I'm sure they work, or if you really want steel ones get someone to fab them up.
74 Std. GL
08 Vw rabbit
18 WR250R
Old February 5th 2007, 17:06
johnnyvee's Avatar
johnnyvee johnnyvee is offline
I know that http://cdoc.com offers scoops in various materials , call them too because they offer a better selection than on the site.
