Old July 10th 2006, 18:38
Jim Hunter Jim Hunter is offline
Smile 930 in 1303
Hi,
I take the final decision to put a 930 4-spd in my 1303.
It is very hard to locate one and if we speak for the early 76-77 model years (3.0l 930 not 3.3l) with the short bellhousing is almost un-obtainable !
So I take a good use '84 long bellhousing for start :
Complete dissasembly of the trans is required due to shorten the bellhousing and the mainshaft by almost 30mm this can be avoided in a buggy or open engine bay car.After the shortening is about 2cm longer from a 915 but is wider a bit so frame horns need to mild haved to let it sit.If you fit an engine with not much HP you need to buy at least 3rd and 4nd aftermarket gears as they are waaaaay tall.Stock R&P is 9:38 but a 8:41 is available in aftermarket.
It can handle easily 550 HP in stock form !!!
This trans can only be compared with a Mendeola for strenght (935 handle 1000HP).Mechanical cluth also.
My question is did you know any to have done this conversion?
Jim Hunter
74 1303 (GL project) *SOLD*
73 1303 (GL project II)
(VW T3s for sale.Panels, 2wd and Syncros)
Old July 11th 2006, 02:59
Hi,
donīt know anyone who did this conversion. But my question is, what kind of engine will you be driving? Is it necessary to work with this monster-gearbox of Porsche?
Even with the Turbo-engines of Subaru we work with the 915, and weīve never had a breakdown yet. The 915 is still easy to get and besides easier to install than the 930. And whatīs even more important is, that you have a 5th gear.
Martin Bott
Old July 11th 2006, 16:09
Talking
Hello,
I will be a "monster" single turbo nitrous injected rotary dynoed at 611HP...
As I will mainly use the car for drag strips R&P size gets my attention.
915 8:31 R&P lasts for about 6 passes then is scrap...
G-50 is very good too but I don't need a 5th for the passes!
I post pics the project begins !
Rgds,
Jim
Jim Hunter
Old August 7th 2006, 08:32
Originally Posted by Jim Hunter
Hello,
Now, I do: www.rojoracing.nl
Its a subaru 2 liter turbo with 'a bit' more hp than stock...
( it does 9.6.. in the 1/4 mile ! )
Old August 8th 2006, 17:32
Hoi Walter!
Het werk van Nice!
Om het even welke meer gedetailleerde info ???
Groeten,
Jim
Jim Hunter
Old August 9th 2006, 01:44
You have Dutch relatives Jim?
Personally I don't know any more detailled info than that there is on that website. Just browse through all pages. There are some very detailled pictures.
Or you could send an email to Robert Jongen who's car it is.
Greetings,
Old November 10th 2006, 03:05
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Some 930 trans into a bug rear shots showing torque tube cut etc. Also STi to 930 adapter plate, 930 centerforce clutch, kennedy STi to 930 flywheel.
Randy
Old August 30th 2007, 10:16
gsusmaniac gsusmaniac is offline
I am going to bring this thread back...I actually have located two 930 trannies...both I think I may be able to get for cheap!
The reason I have been looking for them is because I bought an STI engine that was supposedly comming with an 091 tranny adapter and flywheel. Instead it came with a 930 adapter and flywheel.
Instead of trying to sell this and buy a different one, I am going to try and use it. Good idea you think?
Old August 30th 2007, 11:39
tom'72's Avatar
tom'72 tom'72 is offline
I'd say go for it, the amount of fabricating to fit either trans would be about the same IMO so if you've located a 930 box for a good price go for the bulletproof one now instead of regretting it afterwards.
Old August 30th 2007, 12:22
Bug@5speed(US)'s Avatar
In another thread I mention just returning from a HPDE, earlier this week.
I can attest to the strength of these boxes. My buddy and also my instructor for this session has a 930 4 speed box. I was quite amazed at what he and his turbo motor threw at this box. Quite IMPRESSIVE.
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old August 30th 2007, 13:37
Well I am starting with a JDM STI V3...more than likely and EVO III 16g turbo. Stock header and up-pipe// with custom dump exhaust.
I am hoping to make around 300 HP and around 260ish torque. So I know this tranny will handle it great, and I should be able to launch pretty hard with it.
What can I do about a Shifter?
Old September 7th 2007, 08:46
2443TT 2443TT is offline
Im about to do this conversion as well. I've scored a 930 box that is the short version so no bell housing mods required.
My conversion is going to use 1988 944 turbo arms, axels, drive shafts, hubs, cv's and rear brakes. The drive flanges on the box need to be machine to allow the 944 turbo CV's to bolt on, but thats no big deal. Im changing to coil-over strut rear suspension as well as the torsion housing will be cut out to move the tranny forward and down.
As for the shifter, i've seen porsche conversions that use the stock shifter and frankly... not impressed. Im going full custom from the start. I recommend getting a copy of the "Its Fun 3 Porsche" build DVD. That video is the primary inspiration for my re-build.
My engine is a 2443cc twin turbo'd intercooled efi engine, which should make around 500-550 crank hp. I'd like to see 430rwhp on a chassis dyno.
Here is the best resourse i've found for this conversion.
http://www.veewrx.com/VWRX-engine-ge...ne-gearbox.htm
This guy has done most of the work the hard way, and isnt afraid to talk about his costly learning curve either. Something that mose of us have gone through at some stage or another.
These gearboxes handle 550hp in stock form with ease, and up to 750 when used in track situations provide adequite cooling for the transmission oil is added. They are basically the same box used in the 935 race cars.
I've also found reference to them being used in a lot of v8 power kit cars, where they typically have monster torque figures being driven through them.
I'll be installing mine stock first, but will likely end up changing the drive ratios's down the track after I find out how my new engine drives and delivers torque.
Keep this thread alive. I'll be posting up my progress for my conversion once parts start coming in.
Cheers,
Ian
Old September 7th 2007, 20:55
I found the tranny is going to cost more than I thought...he decided he would let it go to me for $2000. He is an actual porsche shop so he knows the tranny is in great shape! I just have to find a way to come up with the money. That is a bit out of my price range....
Old November 2nd 2007, 08:03
Did you manage to purchase the tranny after all?
Just curious: do all the 930's feature LSD? If so, that price is not much at all, as a good LSD may cost that alone...
Old November 5th 2007, 17:40
I dont know about the LSD...I have half the money saved up...only a thousand to go and its mine!
Deffinately still workin on it though!
