Old July 11th 2006, 09:26
turboL turboL is offline
Msd 6al
Hey anyone runnin MSD 6AL with fuel injection,just about to set mine up so any help would be cool,Im running a billet dizzy and proberbley motekECU on a 2.4 turbo motor built by scat with comp elliminator heads CB perf throttle bodies blah blah any help would be greate! Cheers JS
Old July 13th 2006, 18:02
judgie's Avatar
judgie judgie is offline
why?
the motec will cover the ignition side of things, and a whole lot better than a msd!
a msd wont do half the things the motec can do, ie boost retard.
cheers rob
Old July 15th 2006, 09:18
cheers
MSD came with the car havent got into the ecu set up yet but I have a msd billet dizzy so was going to use a reluctor interface so the ecu can control the MSD igniton,dizzy signal goes to the ecu then the ecu tells the msd6 what to do,I didnt know you could connect the MSD dizzy directly to the ecu,but hey Im new to all this and trying to work it out as I go so I will look into it thanks,any advice setting up electronic fuel injection would be greate thanks JS
