Old July 28th 2006, 14:48
vwdevotee
Ideal GL candidate
So, after I finsh my KG project, I'll be looking for another (I get bored REALLY easily). So, I was thinking pure German look, autobahn bomber (ignoring that I live in the US). I'm talking about a full FIA spec rollcage, a 3L type 4, a 915 tranmsission, Big Reds (at least), 996 GT2 (18x8 f, 18x12 r) wheels, and wider fender to hide them. What would the ideal starting car be for something like this? Should I look for a superbeetle, or a standard? I would love to put it all under an older body (split or oval), but am worried about handling. For pure performance, is the superbeetle the way to go? I've read about people putting 944 struts and control arms in the super, but how superior is it? Thanks a lot.
Old July 28th 2006, 23:28
For me it is the Super(ior). I want to do a 75 next as it has R&P steering.
Old July 29th 2006, 14:01
vwdevotee
So, a '75 or later Super is the best starting platform?
Old July 29th 2006, 16:21
Later than '75 would be a convertible only.
Old July 29th 2006, 17:29
vwdevotee
well that just won't do...
Old July 29th 2006, 17:34
Mikey's Avatar
Mikey Mikey is offline
Really? You're talking about '76 and up supers right?
Mike
'04 R32 Tornado Red
Old July 29th 2006, 18:45
vwdevotee
OK, now I'm confused...
Old July 29th 2006, 19:57
Mikey's Avatar
Me too. We have two '75 supers sitting at the shop right now. Both are 'Sun Bugs'. Both have the metal sunroof in them. I thought the Convert only years were '78 and '79. I'm not even 100% sure about '78 but I know '79 was a vert only year.
Where are you vw? If you're close to Kentucky and you want a '75 sunbug look me up.
Mike
'04 R32 Tornado Red
Old July 29th 2006, 21:43
I went through the same thing with oasis on another post
Old July 29th 2006, 22:22
vwdevotee
Thanks for the offer, but I live in seattle. Towing would be a financial hemmorage. I'll just have to find one locally.
Old July 30th 2006, 14:33
Standard Beetles were imported into the US officially until 1977 model year.
Super Beetle sedans were 1971-75. The flat-screened 1302 was 1971-72; the round-screended 1303 was 1973-75.
Convertibles were imported through the 1979 model year. They were all Super Beetles 1971-79.
US special editions:
Sun Bugs were 1974-only. Sun Bugs were standards with sunroof, Supers with runroof, and converibles in a gold paint scheme. VW imported other 1974 standards, Supers, and convertibles that year as well.
La Grande was a 1975 Super Beetle. It was a special edition but that was the only Super imported into the US. There were standards and convertibles that year. La Grande was advertised as being blue or green but there were gold ones as well. They are often mistaken as being Sun Bugs but if they are a 1975 model, they are not Sun Bugs.
All Super Beetles through 1974 had the steering box. All Super Beetles 1975-79 had rack and pinion. The steering box models had a better turning radius. Rack and pinion was immediately responsive.
http://www.sebeetles.com lists all of the details of these and other special editions through the years of Beetles worldwide.
Old July 30th 2006, 22:31
Komet's Avatar
Komet Komet is offline
Correct, though I thought the '79 production spilled into like May 1980 because of the high amount of orders
Old July 30th 2006, 23:21
vwdevotee
So, if the rack and pinion steering is preferable, can I put a '75 panhead under a 1302 body? Personally, I prefer the flat windscreen.
Old July 31st 2006, 02:15
Originally Posted by Komet
Correct, though I thought the '79 production spilled into like May 1980 ...
Actually, January 1980 (don't make me look up the exact date ) ... they were still 1979 model year, however.
Originally Posted by vwdevotee
... can I put a '75 panhead under a 1302 body? Personally, I prefer the flat windscreen.
The answer is no. However, a 1302 can be converted to r&p. There is some fabrication involved -- more than I care to do or have done, but less than what a lot of others are doing at this site for other endeavors.
I no longer have the notes on the procedure. If no one responds here on this thread, try a search here and at SBO. I know some of that lost info I got was from these two sources. It probably won't be an easy search as you may get many hits that do not deal with it and you may have to go back into some older threads. If that is unsuccessful, try starting a new thread about it. I know it has been done. I think maybe even a member or two here has done it.
Good luck.
Old July 31st 2006, 02:38
Y'know, vwdevotee, I looked at your original post and I think you should reconsider. Do what you want, f'sure, but just consider this ...
You have these great plans stated. You called it an "autobahn bomber." I think you should consider doing a 1303 -- and since you are looking at r&p as a priority, a 1975 model specifically.
Don't get me wrong. I have a 1971 Super myself. I like the flat screen, too. But if you are going for a full-on German Looker, don't you want one that is aerodynamically superior? A 1303 because of its round windscreen is that.
Now, we all know Beetles -- Super or not -- are not the most aerodynamic beasts to begin with. They are fun to manipulate into our own works of functional art. If a flat screen is more important than the fraction of a difference advantage of a round screen, by all means get a 1302 and do the r&p conversion. I'm just throwing out some ideas that have rattled through my head.
Originally, I was going to do an all-out 1975 1303. I stumbled across the car I have and bought it. My ideas for it became more subdued. My next car -- whenever that might be -- will likely be that '75. Then again, I like both flatties and roundies.
