Old July 29th 2006, 13:59
vwdevotee
944 or 911 suspension
I'm looking at doing a GL super as my next project, and I was wondering, are 944 the only porsceh suspensions that will bolt it? Or, can I make 911 parts fit? I have seen the bits from an '89 Turbo, and they look pretty similar. Really though, I was thinking 996 turbo parts.
Old July 29th 2006, 21:59
944 arms are the only "bolt in" option. The aluminum arms are the best choice as the steel one's are about the same as the VW.
Old July 29th 2006, 22:20
vwdevotee
What about up front? What will bolt into the strut towers?
Old July 29th 2006, 22:28
That i'm not sure about(I have a standard '70 bug). If you do a search on here for "944 struts" you should get something. I have read on here in the past about people using them, but having camber problems. Not sure about the fix for it though.
