Old August 1st 2006, 11:59
flat flat is offline
Shop cleanup.....Parts FS
I'm trying to get sell off some stuff because it's getting a little hard to walk around the shop without tripping...
86T (Low offset) 944 alum arms, with hub and ebrake stuff (shoes, hardware) $C300, no calipers or disk.
944 Stub axles (T1 splines, with 100mm joints) $C80 pr
944 spindles (Early and late NA), $C40/pr
Rear 944 brake setups (backing plate, hub, ebrake hardware, NA calipers) $C335 (IRS), $C350 (SwingAxle).
www.vdubengineering.com
Old August 10th 2006, 15:20
Open to offers....(reasonable ofcourse).
L
Old August 14th 2006, 14:42
944 Master cylinders..$C100ea
944 front brake caliper NA with pads $C210pr
Old August 16th 2006, 07:54
More stuff...
MK4 1.8T passenger strut (complete) $C40
73-39 Bus front calipers (with almost new pads) and rotors (pr of each) $C40
Super beetle disk brackets (for KG brakes), not mine but from a CIP kit..$C40
Single Dellorto 40 on DP middle manifold. No filter of throttle cable $C210
Blank fron KG rotors (NEW) $C100 pr. Drilled to any pattern and studded M12 $C150. (M14 studs extra)
Easy,
Old August 24th 2006, 15:08
Edit on prices above...
Also,
Audi TT billet hubs and brackets for CD dropped drums spindle, cosmetically challenged, $C400set. Uses 312x25 rotors and mk4vr6/1.8T calipers.
Same as above but for A3 VR6 rotor (288x25), $375set.
Old August 30th 2006, 07:48
Complete 944 steel IRS arms with stub axle, all NA brakes (except rotor).
$C400pr.
