height setup for 915 box.
locating the 915 box .its 75mm forward but what height should I go for .where it sit,s now the bottom of the gearbox is level with the gearbox forks or should I move it up higher.any ideas welcome.
![]() ![]() ![]() ![]() cheers Malcolm. Last edited by 56oval; August 12th 2006 at 14:11. |
Any ideas? Personaly I would move it up for ground clearance, but what engine are you going to use?
Is that the tunnel you're using, there is no suspension. What are you going to be doing for suspension? Looks interesting, and I like the way the 915 looks.
Mike '04 R32 Tornado Red '02 New Beetle TDI - Daily driver '64 Ghia - Project!!-Subaru EJ20T, MS/EDIS, 993 brakes, 914 Tranny... |
mike if you look up 56oval title 56moneypit on this forum you,ll see the rear torsion bar set.the motor type4T or subie.
for type 4 I'd leave it at a fairly stock height, for scooby raise it as far as you can keeping it within the stock silhouette of the body.
I thought you were going to use an uncut 944 rear torsion housing though? I would have thought that will dictate how far it can go forwards, if at all.. Rich
http://www.ricola.co.uk |
