Old August 9th 2006, 10:59
espenq espenq is offline
944 disc brakes on 1969 Karmann ghia front?
Hi.
This is an excellent forum. For those of you who are old enough, remember what it was 20 years ago when we were fixing up our vw's! You could only ask other people you knew, and if you heard about some modification done far away, you couldn't get any details of it. Internet has changed everyhing.
Back to the question:
I have a 1969 Karmann Ghia conv., and I have bought a complete set of porsche 944 N/A brakes (1984), (backingplate, rotors, calipers, hub).
Fitting the rear brakes will not be any problem at all, it is basically bolt-on. But the problem arises with the front brakes.
My Ghia has originally disc brakes in front, but how can I fit the the easiest way?
Do I have to maschine the hubs so that they can use VW-bearings?
Do I also have to make an adapter so the calipers will fit? Or would another model of the 944 brakes be more fit?
I really hope you guys can help me clear things out.
Regards,
Espenq
Norway
Old August 9th 2006, 11:26
www.vdubengineering.com
Old August 9th 2006, 11:30
Originally Posted by wrenchnride247
Thanks.
I have looked there, but I couldn't find the answer. I also have written to mr. Lanner, but I haven't got any answer yet.
Old August 9th 2006, 11:33
He might be out, and not checking email yet, give him time, he will answer. He did my '87 944T brake set-up. Very nice machine work.
Old August 10th 2006, 04:31
Syncronaut Syncronaut is offline
Hi Espen,
shoot me an e-mail and I can send you a scan from a web-site nla. Please send to guttorm(at)gmx.net
An old source for this info is the German book Bodengruppentherapie by Helmut Horn:
http://www.tuning.de/html/index.php?...8ff2a1374c6d5d
Gorm
Old August 10th 2006, 05:11
Mikey's Avatar
Mikey Mikey is offline
The better route to take would to machine a spacer to use stock vw bearings and races in the Porsche front hubs. There will be a gain in offset. Along with the rear. Lanner already has the spacers figured out, although I believe he would have to machine your hubs for the grease seal. And shorten them just so they'll fit on vw spindles. After that he might be able to mount a caliper braket on your stock spindles. You'll have to ask. I asked about 944 NA fronts a while back, and that is about everything I remember from his emails. They were clear and easy to understand. I hope it helps.
His site is a good referance too.
Offset is a something you should keep in mind, the rear 944 NA brakes add track (move the rear wheels away from the suspension) to the rear wheels. The front will also add track. I bring it up because I'm building a Ghia.
Good luck.
Mike
'04 R32 Tornado Red
Old August 10th 2006, 06:15
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Don't they make a translator that can sit on your shoulder and read german from that book to us...like a bed-time story...
Old August 10th 2006, 11:21
I have drawings of the spacers and mods required for this swap on my website, in the speedster section
Old August 11th 2006, 02:28
bt1211 bt1211 is offline
Sorry about the highjack
Mikey, How is your car coming along? I am the guy that was talking to you at the mid-america show.
Bryan
