Old August 11th 2006, 00:35
chug_A_bug's Avatar
no spark Y
ok guy this is driving me crazy I have tried 3 different DISTRIBUTOR nows
the stock one with ponits and then switched it to hi output electronic ignition
and that didn't work then I BOUGHT a NEW distributor with the electronic ignition already installed and that didn't work then I just tried my grilfriends 009 from her 72 bug and that didn't work. so what's going on??
I have a 69 bug 1600 single port and I have power B4 the coil after the coil my everything has been looked over ten times it's all right no cut wires nothing that would not stop it from making SPARK and I'm stillnot getting it all new parts too so I just don't get it please help.
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old August 12th 2006, 09:14
brujo65 brujo65 is offline
hi Chris first let go to the basic Ok
1- turn the ing on you have power on the + off the coil
2- Ck your firing order 1-4-3-2
3- try a new or a running coil
4- Ck your spark plugs ( used NGK ) bosh:disagree:
Old August 12th 2006, 12:29
chug_A_bug's Avatar
Red face
hey brujo thanks for your help but I have tried all that B4 and tha's what's killing me it's soo simple but it's just not firing up it's turns over I have power on and off the coil all gronds have been checked I made sure that the dizzy is all the way down and clamped I even have a spark tool and it's shows nothing, I knwo the firing order it's TATOOED on me I just don't know what's wrong I'm had my uncle look at it and he's a machanic and still nothing it ran last summer put it away for the winter and now nothing oh and now I'm going to try the NGK plugs thanks for that one
74 Std. GL
08 Vw rabbit
18 WR250R
Old August 13th 2006, 06:29
1303R's Avatar
1303R 1303R is offline
hey, still no joy aye?. could be a bad live feed to the coil, you checked to see what voltage your getting when cranking? i'd try putting another wire in, just run one temporary, could even run it off of another battery just to check. just be carefull, must be loadsa fuel about if its not firing. good luck
Old August 13th 2006, 16:33
chug_A_bug's Avatar
hey thanks for your help I have tried a dumby wire too and I still got nothing I crank it over and I got my 12v B4 and after and I'v put a new Bosh coil on it too and still nothing I'm at the piont of just forking out the 250$ for a new wiring harness but really don't want to do that but if I have too the so be it. I just don't get it it ran last summer just fine put it away for the winter and now been working on it this whole summer trying to get it to run well anyone in the area that wants to come help that would be cool too
74 Std. GL
08 Vw rabbit
18 WR250R
