Old August 14th 2006, 05:57
jimby jimby is offline
IRS race gearbox with Quaiffe ATB diff
Ive got a john maher racing IRS single side plate gearbox for sale. it has got installed a Quaiffe ATB active torque bias differential. it has a brand new NOS crack tested VW german 3.88 ring and pinion. a superbeetle main shaft, new syncros, steel shift forks, welded first and second, close ratio third and fourth, type2 output shafts.
ratios
3.88 rp
3.78 1st
2.06 2nd
1.58 3rd
1.12 4th
here are the gear ratio caculations for mph with a 195 60 R15 tyre
per 1000 revs = 17mph
so at
6000rpm your doing 100mph
7000rpm your doing 116mph
8000rpm your doing 133mph
with a bigger 'cal look' style tyre on the rear a 205 70 R15 the gearing is taller
per 1000 revs = 18mph
so at
6000rpm your doing 108mph
7000rpm your doing 126mph
8000rpm your doing 144mph
CALCULATIONS TAKEN FROM THE www.johnmaherracing.co.uk gear ratio calculator and tyre diameters taken from the yokohama website.
please call me on 07815 288850 im in west london, england. or email me at jimby@hotmail.com.
£1300 or very near offer
