Old August 22nd 2006, 14:32
Bullyboy Bullyboy is offline
FS 46mm Kadrons
1 pair 46mm Kadrons done by AJ Sims @ Lowbugget.com (1 seasons use).
$400 CDN plus shipping from Canada
46mm throttle bodies c/w urethane/vinyl bushings
CNC 32mm venturies
air top kit adds up to 7cfm
Vent Kit that will allow you to run as hard as you want without that stumble.
155 main jet, 55 idle, and a 175 air correction jet
also tapped for a vaccum advance
Scat linkage
Welded and ported manifolds
If you buy from Lowbugget they are:
$589.99 46mm and Power kit (air top, vent kit, CNC vents, bushed throttle assembly)
$50.00 Scat linkage
$40.00 Tap and install vacuum port for vacuum-advance distributors
Old August 24th 2006, 23:27
Pictures added for those interested
I am told by a reliable source that the carbs would work well on 1776-1915cc motors.
Old August 28th 2006, 21:36
sale pending
Old September 26th 2006, 06:00
Phat73VW's Avatar
Phat73VW Phat73VW is offline
are these still available?
BRIAN
Old September 26th 2006, 08:39
sold last tuesday
Sorry Brian
