Old August 30th 2006, 07:46
flat flat is offline
Boxster Brake brackets
I've got the rear Boxster brake caliper brackets. Works with all 944 setups, and uses the 944NA rotor. It's a good combination of efficient (and sexy) Boxster caliper with the lighter NA rotor so you can reduce your unsprung weight.
$C190 pr with hardware.
www.vdubengineering.com
