Old August 30th 2006, 10:03
zeroaxe zeroaxe is offline
Bend pushrod on #4 intake
People,
I need your help/advice please.
This is now the second time that my engine has bent the pushrod and tube on #4 intake. That is why I cant get this engine fired up. After replacing it the first time, I could get the engine fired up and running(although very badly) for a short time until it reaches the point where it dies, or doesnt want to start anymore. I am 100% sure that the reason is this bent pushrod.
Now, this motor has been completely rebuilt with fresh 1776 pistons and barrels. "Supervised" by my previous boss, who is supposed to be a pro. I have mentioned to him the first time about the rod, and asked "Why did this happen?". To which he responded that "it happens". One maybe, but twice in a row..., same rod? I have lost my confidence in him, so I turn to my internet buddies where I am sure, between so many people, I am sure to be able to find the answer/reason. I would hate to strip this motor down to the bone again, but if I have to, I will(have to).
In my time of need, I ask the fountain of knowledge for help.
Thanks fellas!
Old August 30th 2006, 11:46
Have you checked your valve stem length? Put a straight edge across all the valve stems, and see if they are the same. Also, Check for coil bind on that valve. Hope this helps.
Old August 30th 2006, 13:42
Thanks for the reply. I think that all the valves are the same lenght, as they are all new and bought at the same time. The heads are recon ones, valves lapped and 'slides' freely in the guides. So that leaves the coils(you are referring to the valve springs right?) and rocker arms.
So how would I be able to check the coil bind? Turning the engine by hand it seems fine, but as soon as I start it up, it fuzz-up. Also, how would I go about checking rocker arms for problems(and what problems can I expect?).
Thanks for the input. I will pull the head covers on both sides and check the valve stems anyway, hopefully tomorrow.
Thanks!
Old August 30th 2006, 21:15
To check for "coil bind" turn the motor over by hand with valve covers off, and watch for the problem valve to be at full lift. Then check the amount of clearance you have between "coils" of the spring. I think the smallest amount you can have is .050(use feeler gauges to check this if you have them) if the gap is bigger, your ok there. Another thing to check (if you can see it through the valve spring) is the retainer to valve guide clearance. This distance should be way more than the "coil bind" clearance (not sure on how much though)
Are the rocker arms new? You might have two different ratios if you got some used ones.
Did the lifters slide easily in thier bores, and with no side to side play?
I'm no "expert builder" by any means, but just throwing ideas for you to try and help narrow the search down. Hopfully some others will help out too.
Old September 1st 2006, 19:40
Thanks for the advice, I will be following it (and others) CLOSELY!
The other night(after you posted it) I read it, but it all went over my head. It was late, and I couldnt really think all that hard(well, I seldomly can! ). I havent given it a once over again(yet), but will do. My first priority is to get that engine out the Vanagon and on the workbench/floor in my workshop(still in the making).
I havent sat on my aR$e though. I have searched the net for "coil binding" as well, for some visual aid. I have not really found something that I could say clears the mud though. Any references would be appreciated though(hint-hint).
I have been thinking about this dilema too. And this is what I have come up with. My previous boss machined the case and heads. The heads was done with the "eye measure" tool. So I think he might have machined the #3 too deep. Giving me a wrong deckhight, causing the intake valve to hit the piston. Would this assumption be correct? This is what I found on STF(which I believe confirms my worries):
Actually Max.. deep flycuts will be the biggest source of rocker geometry corrections. If the heads were stock and the case was stock too, going to 1776cc should not do anthing different..given using stock rods. If you machined the decks of the case and flycut the heads the motor just got shorter. In essence, the push rods got too long and the only way to put the rockers back to baseline is gain some altitude with the rocker posts.
The first time when it happened, I took the other/old head off, because I thought that the valve was sticking. When the head was off, I didnt notice any marks on the piston though. Although, it was 'carboned up', if that makes sense. For new pistons, it was black with a 'crust'. I found that disturbing, but didnt make anything of it, as I was guided by a pro when putting all together. So it must've been right.......RIGHT? I know better now. If you want it done right, do it yourself - after some proper research, if you dont know how already. I realise that I dont know that much, but I am learning, thanks to you guys :agree:
So i am not going further with this at the moment, before the engine is back on the stand and stripped to bare case(with c/rods, c/shaft, cam shaft etc installed), or should I strip it down completely and start from SCRATCH?(i.e. is there anything else that he might've missed inside that would cause serious problems later?).
PS. I do think I have got the Cam manufacturer wrong, but still think the "110" is correct. I will try and found the packaging/ask me previous employer.
Old September 1st 2006, 23:02
I was starting to wonder if you were getting anywhere. I guess the best way too describe "coil bind" is turn the crank pulley(with valve covers off), and watch the problem valve until it is completly bottomed out. Then if you can't see a gap between each coil of the spring... you have coil bind. I'm sorry i'm not very good at internet directions, more of a "hands on" kinda person.
If the case deck, or heads have been machined different from bore to bore, then you couldn't seal the cylinder too the head correctly, leading to major leaks, or cracked head or case .
As for your cam. When looking at the cam out of the case (i can't remember if you can see this with cam in case, while heads and pistons are off) , you should check to see if the cam gear was installed correct. There is a mark on the cam gear. The lobe on the cam farthest from the gear should be facing DOWN. If not, your cam timming is way off (carbon and oil on pistons, poor running, or not running) then this would be your problem (I forgot about this in previous posts )
Old September 2nd 2006, 07:08
Technically, I wasnt getting anywhere, because I did not manage to get more work done I am also a more of a hands-on person, that is the way I learn(computers, mechanics, DIY... everything really), But I like to try and find info before hand
I am worried about the machining of the heads. As they might appear to be the same depth, they might not be So my question is this. since the motor hasnt really been run/driven yet, I dint think that anything might be cracked. So with shims, I should be able to get them all sorted out no?
As to the cam, I believe it is properly installed(well, I hope the advice I have been given was correct!!!) As the dot on the cam and C/shaft lined up. But once the motor is out, I will try and verify this too. Considering all, I cant be too safe/sure about anything anymore.
Old September 2nd 2006, 21:45
Shims are a step in the right direction, but they will screw-up your static compression ratio per cylinder if they are not all the same per chamber. The chamber volumes must be the same(or very close)for the motor to run good, same goes for shims under the cylinder. If you put shims under the cylinder, or copper gaskets in the head chamber they must be the same for ALL cylinders. Example, in one chamber you have a .030 gasket and a .060 in the chamber next to it to get the head to sit level on the cylinders, you will have a different volume in each cylinder(poor running motor). The only way to correct the depth is to remachine the chambers so they are the same. Then you can use gaskets, and or cylinder spacers, to get a good compression ratio. Sorry .
Old September 3rd 2006, 10:42
Bugger. That is not good news. A good waste of new(recon) heads My previous boss flycuts them with the 'eye level' measuring tool
Old September 4th 2006, 19:14
So, I was advised that pistons build up carbon fairly quickly. Well, not that quick! Look at the pics below. I kid you not, there is not Photoshop'ing going on here, it's the same engine! #1&2 is clean(and corrosponding head), but check out #3&4!! And this is after about a total of 5minutes of the motor running(however, I didnt clean the #3&4 pistons the first time around).....
Heads:
(clean ones are #1&2. Also bear in mind these are the new recon heads that I have *just* had done)
#1&2 piston heads:
#3&4 piston heads:
So looking at these pictures, would you think that there is something else wrong somewhere?
Old September 4th 2006, 20:57
That is weird! All I can think of is the piston rings on #3 and #4 some how got the gaps lined up so oil just went right to the head chamber. It's strange that it happened only on one side, and not the other side. They could have been damaged installing them also, or installed upside down.
Old September 4th 2006, 21:22
Oh yeah. Forgot to ask about that engine case. It looks like a industrial engine case(don't remember the case code)that was used for non motor vehicle application's (running generators, compressors, and machinery If I remember right). I'm sorry I keep telling you bad news . It's not on purpose at all. Just trying to help.
Old September 5th 2006, 19:02
Piston/head #3&4 revisited:
After some wire wool this is how the pistons look like after cleaning up:
On both pics you can see where the intake valve nicked the piston head, but is very clear in the second pic. No doubt that the deck high is way off. The "pro" that did the fly cutting on the heads cut them too deep...
Yikes! I am sure I put the rings on the right way..., or did I? Well, I will be pulling the sleeves off at some point now too! As to the case, I will verify the code tomorrow. This should be a stock Vanagon case. I did not mention it the first time round I think.
Old September 5th 2006, 21:32
I remember about twenty years ago seeing a typeI style case with a oil filter on the block, and was told it was a "industrial case". I have not looked at a vanagon case though.
If you get your heads machined to the same depth, you should be able to adjust your deck height with cylinder shims, and your head chambers with copper gaskets to get a good compression ratio.
Old September 6th 2006, 05:18
Are you that old!!?
As a matter of fact, I have got 2 of those engines here too. I did not notice though if they had the oil filters.
It is good news to know that the head might still be saved. Problem now is to find who can do them. Anyone know where the fly cutting tool can be bought?
