Old September 3rd 2006, 13:31
Bad bug's Avatar
Bad bug Bad bug is offline
3 bar kafer cup brace
How strong is the 3 bar cup brace in holding a 2.9ltr type 4 engine
Old September 4th 2006, 10:50
Mark the canuck Mark the canuck is offline
Got one on a 2.6, ripped the stock rubber mounts off..replaced with red urathane mounts. So far so good.
74 914-6, six conversion in progress. Major progress, twin plug macining done and all the parts coming together for a for a hot street 3.0.
'67 kombi, 2007cc, Summer daily driver.
'67 bug, painted and waiting for assembly, Empi GTV project, 102mm Nickies, 78mm crank, SDS FI, 2.6L T4 monster in the works. Now 98% done, just need to work on the the motorcycle ITB intake.
Old September 4th 2006, 13:48
I am not sure how strong it is but when you connect it to the frame horns and the shock towers, it makes these items very rigid. If you hit any one of these items with a hammer after installing, you get a very solid sounding ring.
I have one installed along with a porsche 901 5 speed .. it holds my 2.0 T4 turbo running at 17 psi with no problems ... I can spin tires in 1st, 2nd and part of 3rd ... no wheel hop, no flexing .... all I hear is squaking tires.
It also makes your whole rear end stiffer. I had to go down a few notches on my adjustable rear sway bar to keep the back end planted during "spirited" driving.
With the red urethane gearbox mounts it makes the car noisier ...
Old September 4th 2006, 19:09
zeroaxe zeroaxe is offline
Are you referring to 'clenching' or the car's suspension?
Old September 4th 2006, 20:35
Bad bug's Avatar
I really would like to have a five bar for my bug but aircooled.net don't seem to have any. Does vdub enginerring have any.
Old September 5th 2006, 03:05
Mikey's Avatar
Mikey Mikey is offline
Yes he does sell a 5-bar kit. I have one. I'd reconmend Vdub Engineering over the ac.net stuff.
Also see www.vdubengineering.com for pricing.
Mike
'04 R32 Tornado Red
