Old September 9th 2006, 21:11
Swepco 201 gear lube in the GTA ?
Hi Guys,
I just rebuilt my 901 with a new syncro band and hub for 1st gear. All the other gear components look great so did not mess with them.
Gearbox is back in the car, so where can I get Swepco 201 gear lube in the GTA ?
Old September 10th 2006, 05:10
petevw's Avatar
petevw petevw is offline
Have you tried Mantis Racing in Oakville?
Maybe the Pfaff dealer?
Why Swepco?
I'm using Shell Helix Synthetic. Very happy with it. Bought from Marranello Ferrari in Woodbridge.
'72 super
'65 bus
'52 split
Old September 10th 2006, 11:06
CLKWRK's Avatar
CLKWRK CLKWRK is offline
Got my swepco from Mark the Canuck
Bryan
GL ghia restoration:
Old September 10th 2006, 12:22
Thanks Guys,
Swepco 201 is supposed to be recommended for 901 gearboxes. I used Castrol Hypoy C 80W90 last year, will try the Swepco 201.
I will give Mark a call.
Old September 10th 2006, 21:32
chug_A_bug's Avatar
hey sandeep you should try royla purple gearold it's great just put some in my girlfriends trans runs like a boooot and I'v put it in my 69 too it's nice too. just a thought
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old September 11th 2006, 14:33
Mark the canuck Mark the canuck is offline
In Stock.
I'll NEVER use Synthetic in a VW or Porsche gear box.
You may like it but your syncro's don't.
74 914-6, six conversion in progress. Major progress, twin plug macining done and all the parts coming together for a for a hot street 3.0.
'67 kombi, 2007cc, Summer daily driver.
'67 bug, painted and waiting for assembly, Empi GTV project, 102mm Nickies, 78mm crank, SDS FI, 2.6L T4 monster in the works. Now 98% done, just need to work on the the motorcycle ITB intake.
Old September 11th 2006, 16:15
chug_A_bug's Avatar
oh really why is that? soo you are saying that I should get it out ASAP and then what should I put in??
74 Std. GL
08 Vw rabbit
18 WR250R
Old September 11th 2006, 20:19
Swepco 201
Mark ... email sent with a few other items I need.
Old September 11th 2006, 22:55
chug_A_bug's Avatar
nice sandeep thanks alot and now I live in the hammer so would you know where I can get that gear oil?? thanks for your help, oh are you going on the coruse on the 17th too?? who is all going??
74 Std. GL
08 Vw rabbit
18 WR250R
Old September 12th 2006, 10:50
67ghiaTIV 67ghiaTIV is offline
Swepco
I ordered my Swepco through Steve Couldrey, he oftens picks up his supplies from a shop here in Brampton and he delivered to my door. After watching his presentation on Swepco he left several of their other products for me to try.
His contact info is. I found his info on the Upper Canada Porsche site.
phone 519-836-1823
cell 519-835-8230
email sgclube@rogers.com
jamie
Old September 12th 2006, 18:21
petevw's Avatar
Why not?
The Shell Helix "euro spec" is GL5/MT-1 rated.
Synthetics with a GL4, or GL5/MT-1 rating are OK for brass synchros:agree:
I do like my tranny, shifts really smooth, hot/cold, cruising around town or beating the snot out of it at the track.
'72 super
'65 bus
'52 split
Old September 13th 2006, 06:39
chug_A_bug's Avatar
hey so why is royal purple so bad? I'v had no problems with it, and the shifts are just great
74 Std. GL
08 Vw rabbit
18 WR250R
Old September 13th 2006, 09:21
From my reading, I've surmised that the "balk ring" syncros in a 901 need friction to operate properly. They are the band that is responsible for making sure that complimenrary gears are rotating at the same speed, therefore when engaged, you get a smooth shift .... no grinding.
Synthetics (I've read) are too slippery for this type of syncro in a 901 to operate properly. The brass slider has little to do with proper engagement of gears, as far as I can tell from looking at the guts of my 901 gearbox.
I want to try the Swepco 201 and see what all of the fuss is about.
BTW, my engine parts should be ready to pick up this weekend
Old September 13th 2006, 17:17
petevw's Avatar
So you'll bring it to the cruise?
'72 super
'65 bus
'52 split
Old September 14th 2006, 16:39
chug_A_bug's Avatar
I'm coming but with my grilfriends 72 std and it's purple ahhhh see you all there I can't wait
74 Std. GL
08 Vw rabbit
18 WR250R
