Old September 24th 2006, 19:39
pl1979 pl1979 is offline
Exclamation Flat 6 in the bus Split
I bought a COMBI SPLIT 15 WINDOWS. But i want put the flat 6 porsche AIRCO with the porsche gearbox with the IRS SYSTEM and the rear axle of 944
Can you help me for find the kit for this conversion ?
Regards
Pascal
Old September 27th 2006, 22:24
Pillow's Avatar
Pillow Pillow is offline
Kit... None.
You are going to haver to hack the piss out of your bus to fit all that stuff in it.
Oil tank. Wide and long flat 6. Not to mention the bigger 915 tranny hassle. Also for the IRS stick with steal arms, any AL ones will make it too wide.
Forget it or open the wallet very wide.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old September 15th 2007, 20:44
Bad bug's Avatar
Bad bug Bad bug is offline
Best if he had a 74 up bus then it would be easy. Better yet a vanagon would solve all problems. Flat 6 are much easier to put in a vanagon. Has being done here in jamaica.
Old September 27th 2007, 04:09
Hebster52's Avatar
Hebster52 Hebster52 is offline
I have the same question regarding fitting the flatsix into a splitty. My engine is a 1969 2,0l engine and I had planned on using a 1303S IRS gearbox. 944 steel trailingarms and brakes. Pros and cons? Do I swap the nosecone from the IRS gearbox to the one from the stock splitty swingaxle gearbox?
Dont ask why I just settle with the 2,0l. That question have been asked before and I answer it by saying that it is what I have in store and secondly that would be the maximum displacement increase allowed in Finland for a splitty... :agree:
I suspect that if I have a good superbeetle gearbox it will cope with the moderate poweroutput from the small flatsix. I'm not building this for racing just building it because I like the combination of a splitty and the porka sound..
Old October 8th 2007, 03:16
Hebster52's Avatar
Unfortunately my -69 911 engine did not have any flywheel when I bought it. What I would appreciate find some info about is if I could use a post-69 911flywheel in combination with the 1303S gearbox? The reason I ask this is that the pre-69 flywheels are priced as they were made out of Platinum compared to later ones...
Old October 11th 2007, 17:07
skywalker
Just like this:
Old October 25th 2007, 18:03
notch11's Avatar
notch11 notch11 is offline
one was featured in hot vws a few months ago its owned by Geoff?? that used to work at airspeed parts in british columbia......if you vist there site there is a complete build procces.
http://www.airspeedparts.com/communi...hp?act=SF&f=20
Old October 26th 2007, 11:58
Hebster52's Avatar
Thanks, I know Geoff from volksrods.com. We've got the same interests He built his Hebrod with inspiration from my unfinished Hebster project too..
We've discussed this through e-mails too. He's got a Porsche transmission too if I dont remember totally wrong.
Old November 1st 2007, 02:42
Hebster52's Avatar
This is how nice the 911 flatsix fits to a 1303S transmission..
Old December 12th 2007, 03:42
Hebster52's Avatar
I started to relocate the transmisson 30mm forward and removed the original front mount.
Then begun to make my own "Berg-mount", just having some thoughts and worries about the engine and transmission hanging on the rubber mounts... So I have now two options for the Berg-mount...
The reason for me to concider the upper mount is that I'm worried about the weight pulling the mounts if they are mounted from the under side...? Maybe I shouldn't worry too much?
It would be just like the 911's have it originally too...
Old December 12th 2007, 05:42
It would be better to have the mounts in compression, that way if they fail, they only move around, not drop everything on the road.
Old December 12th 2007, 06:39
Hebster52's Avatar
In other words like the upper version then? That was the main reason I concidered that design too..
I just assumed that the weight of the transmission and engine would be more stress to the mount than the power the transmission tend to press the nose upwards when accelerating?
Old December 12th 2007, 13:12
chug_A_bug's Avatar
hey just my thoughts on this I too think the upper version would
be better just use some Good 1/4" Plate and Guset the **** out of it lol
plus like what Steve C said it would just Hang it it did Brake, and Not fall to the ground. Just my to cents.
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old December 12th 2007, 20:49
The top mount version would provide safety if the mount failed, but would seem to make removing the tranny quite a bit more difficult, as well, when the tranny is loaded during acceleration, the top mount will be in expansion, not compression, and this force is going to be working every time you accelerate.
As well, as I recall, those mounts have a bolt running through them, not just into the rubber, so the safety is there regardless? Might want to look at more modern motor and tranny mounts, if your fabbing up might as well make use of something with a better design?
My 2 cents...
Old December 12th 2007, 20:53
Originally Posted by skywalker View Post
Just like this:
Not so sure that's a sound replacement for hacking out the middle of the torsion tube. The top square tube is welded to thin sheetmetal with no additional plate to spread the stress. That will fatigue in no time IMO.
