Old September 26th 2006, 11:33
Titanium valves
What are the advantages of using titanium valves?
T4 2666 1303s
Old September 26th 2006, 14:58
JIMP JIMP is offline
Hello
as far as I know their only advantage is smaller weight vs the stainless ones. In my opininion they have place only on VERY high revving, big valved racing motors, like let's say drag cars. They make the whole valve train system alot more easy to be handled by the springs, so even more aggresive cams may be used. BUT they are significantly proner to breakage because there aren;t as strong as the stainless ones, so in my opinion they are not very applicable on a street car (even high performance). We could say that for the serious racer guys its a necesity that they cannot avoid and for this reason they are inspected in every given chance and eventually changed so as to be sure that the engine will not be destroyed. Oh, they are expensive too!!
Hope to be of a liitle help
JIMP
Old September 30th 2006, 10:00
Thanks for the reply. Will go for the stainless ones.
T4 2666 1303s
Old November 5th 2006, 01:11
Bugger Bugger is offline
Not to confuse things, but isn't stainless actually weaker then the normal hardened steel that is used on valves? I know that most things that are made of stainless compared to there counterparts in steel are weaker, chains, bearings etc. Stainless has great corrosion resistance which is why it is so desired in things like exaust. Stainless may be stronger in unhardened form than certain steels in unhardend form, but hardened steels are always stronger than stainless.
Old November 19th 2006, 10:35
What bugger said is totaly correct. Just to add a bit
titanium isn't stronger than stainless. it has greater impact strength thus its more brittle, but due to it's advanced molecular grid is superior to the stainless (this brittleness will eventualy appear at very high load conditions, compared to stainless). This means that it can sustain higher continous loads over stainless steel. thus is better for high impact applications. also it has much better heat capacity, thats why its used primarily for ex valves
Chris
Aircooled 4ever
1973 1303 going towards GL
Old December 26th 2006, 09:17
marco the T.S.E marco the T.S.E is offline
Chris
i don't think that is totaly correct!
