Old October 18th 2006, 20:24
64bug's Avatar
64bug 64bug is offline
9" wides
Anyone get 9 inch wide rears to fit under 1 1/4" wider rear fenders? Or under what wings? Pictures?
Old October 19th 2006, 18:40
yetibone's Avatar
yetibone yetibone is offline
It's not likely you could use 1.25" wider fenders over those wheels.
I couldn't fit 17x9's under 2" wider fenders without removing the little bumpstop landing pad from the shock towers .
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old October 19th 2006, 20:15
64bug's Avatar
Right now the wheel are about 5-7mm from the adjusting block on the spring plates. With no spacers. SO their all the way in. It looks like it would be close tryin to compare my stock fenders.
Old October 20th 2006, 19:13
fastdub fastdub is offline
i put a 9x18" turbo twist on the rear of my bug today and i reckon with a 10mm spacer i could easily get them under 2" wider rear wings
