Old November 20th 2006, 15:51
JiI's Avatar
JiI JiI is offline
Exclamation replacement lower front ball joint
Anyone know of an aftermarket ball joint that will fit the bottom of the spindle on a 75 superbeetle? I'm redoing the front suspension and would like to find a balljoint that will fit the spindle that isn't a press-in unit to the arm like the original, but instead, a bolt-in. The suspension is all custom so I won't be using the stock lower arms. Any help would be appreciated. Thanks.
JiI
"If at first you don't succeed, give up, there's no sense in making a fool of yourself."
Old November 30th 2006, 00:55
The Pirate's Avatar
The Pirate The Pirate is offline
Som of the early Audies have a bolt on that should be the right size.
Pirate VW Services is looking for weber IDF and IDA carbs "to far gone to repair". We are also looking for 74 Super Beetle and later controll arms that are to badley bent to use or repair. PM for details.
Sevice with a yarrhhhh!
