Old November 24th 2006, 17:55
buggyboyshane buggyboyshane is offline
would these wheels fit??
CUTLASS IN 16 x 8 , WITH 4 OR 4 1/2 INCH BACKSPACING - their words.
Old November 24th 2006, 18:55
Bullyboy Bullyboy is offline
On what? ghia, beetle, type III, typeIV, early bus, late bus, baja, sand rail???
Old November 25th 2006, 00:38
LLVWGL LLVWGL is offline
with enough money and modification, anything will fit. how much money do you want to spend, how much fabrication do you want to do, what type of car, what year?
The details of your post are INCREDIBLE!
Old November 25th 2006, 07:23
**** guys sorry-
56 oval, narrowed front beam. stock narrow rear gonna run on air ride chassis
Old November 25th 2006, 11:53
lol, how much is the front narrowed by
Old November 25th 2006, 13:09
3 inch, have set of boxster red 4 pots hopefully goin on behind them.
Old November 27th 2006, 04:38
how you adapt the Porsche brakes will also affect the track width so is another variable to add to the list!
Old November 27th 2006, 09:18
was just going to mill down the disk/drum fitment too act as a hub, then attach disc tha way.
Old November 27th 2006, 10:36
If you don't thin the old drum/disc, that will give about a 6mm increase in track per side.. I presume you are using new Porsche drilled discs to machine down? I don't think stock ones have enough meat on them for 5 stud hubs.. I used some MBT hubs for my conversion.. Oh, are you usign stock front wings too?
Old November 27th 2006, 14:07
yeah stock front wings, as for the disks/drums, was gonna get machine 7 style ones- (not redrilled, but in porsche pattern) and turn them down on the lathe.
Old November 28th 2006, 05:13
right:
from most bugs I think you can use a 7" wheel with 40mm offset so will use that as a 'limit'
Offset = Backspace - (Rim Width ÷ 2) = 114.3mm - 101.6 = 12.7mm offset, that's not a lot with 4 1/2" backspacing!
For an 8" wheel on stock front end you will need 52.7mm offset:
start with 12.7mm
gain 1 1/2" from narrowed beam = 38.1mm
lose 6mm from disc width
that gives you: 12.7+38.1-6=44.8mm
Sorry, not looking good, it also depends on what tyres you use.. Having 8" wheels up front under stock wings will also greatly limit your turning circle unless you heavily modify the inner wings...
