Old November 26th 2006, 21:21
naaz90 naaz90 is offline
Watson street works wiring problems
I purchased a watson kit for my 72 ghia and am now regretting it.
I have many issues but I will only ask for help with one of them now. The kit seems to be geared more towards pre '72 year cars, mainly cars without the ignition switch in the column.
Here is my question. They say to run a wire from the fuse box to the column for "TURN SIGNAL SWITCH FEED". Where do I connect this wire??? The only wire I can possibly think off is "49a". Is this right? Or do the column switches already have power???
I'm so confused. I know some people have had great success with this kit and some hate it.
Old November 26th 2006, 23:32
Bullyboy Bullyboy is offline
These are the standard designations for the terminals
hope it helps
And the stock wiring diagram
http://www.thesamba.com/vw/archives/...ing/72ghia.jpg
From Bosch Automotive Handbook, 3rd edition
Terminal Designations (Excerpts from DIN Standard 72 552)
The terminal designations do not identify the conductors, because device
with different terminal designations can be connected at the two ends of
each conductor. If the number of terminal designations is not
sufficient (multiple-contact connections), the terminals are
consecutively numbered using numbers or letters whose representations
of specific functions are not standardized.
Terminal Definition
IGNITION
1 Ignition coil, ignition distributor, low voltage
(Ignition distributor with two separate electrical circuits)
1a to ignition contact breaker I
1b to ignition contact breaker II
2 short-circuit terminal (magneto ignition)
4 Ignition coil, ignition distributor, high voltage
(ignition distributor with two separate electrical circuits)
4a from ignition coil I, terminal 4
4b from ignition coil II, terminal 4
15 Switched + downstream of battery
(output of ignition/driving switch)
15a Output at dropping resistor to ignition coil and starter
GLOW PLUG AND STARTER SWITCH
17 Start
19 Preheat
BATTERY
30 input from + battery terminal, direct
30a input from + terminal of battery II
(12/24 V series-parallel battery switch)
31 Return line to battery
- battery terminal or ground, direct
31b Return ine to negative battery terminal or ground, via switch
or relay (switched negative)
(12/24 V series-parallel battery)
31a Return line to - terminal of battery II
31c Return line to - terminal of battery I
ELECTRIC MOTORS
32 Return line
(Polarity reversal possible at terminals 32-33)
33 Main terminal connection
33a Self-parking switch-off
33b Shunt field
33f For second lower-speed range
33g For third lower-speed range
33h For fourth lower-speed range
33L Counterclockwise rotation
33R Clockwise rotation
STARTER
45 Separate starter relay, output; starter input (main current)
45a Output, starter I
Input, starters I and II (Two-starter parallel operation)
45b Output, starter II (Two-starter parallel operation)
48 Terminal on starter and on start-repeating relay for
monitoring starting procedure
TURN SIGNAL FLASHER
49 Input
49a Output
49b Output, second turn-signal circuit
49c Output, third turn-signal circuit
STARTER
50 Starter control (direct)
50a Output for starter control
(Series-parallel battery switch)
50b Starter control with parallel operation of two starters with
sequential control
50c Input at starting relay for starter I
(Starting relay for sequential control of the engagement
current during parallel operation of two starters)
50d Input at starting relay for starter I
50e Input, Start-locking relay
50f Output, Start-locking relay
50g Input, Start-repeating relay
50h Output, Start-repeating relay
ALTERNATOR
51 DC voltage at rectifier
51e DC voltage at rectifier with choke coil for daytime driving
TRAILER SIGNALS
52 Signals from trailer to towing vehicle, general
WIPER MOTOR
53 Wiper motor, input (+)
53a Wiper (+), self-parking switch-off
53b Wiper (shunt winding)
53c Electric windshield-washer pump
53e Wiper (brake winding)
53i Wiper motor with permanent magnet and third brush (for higher
speed)
TRAILER SIGNAL
54 For lamp combinations and trailer plug connections
TRAILER STOP LAMP
54g Pneumatic valve for additional retarding brake,
electromagnetically actuated
LIGHTING
55 Fog lamps
56 Headlamp
56a High beam, high-beam indicator lamp
56b Low beam
56d Headlamp-flasher contact
57 Side-marker lamp: motorcycles, mopeds.
Abroad also cars, trucks, etc.
57a Parking lamp
57L Parking lamp, left
57R Parking lamp, right
58 Side-marker lamps, tail lamps, license-plate lamps and
instrument-panel lamps
58b Tail-lamp changeover for single-axle tractors
58c Trailer plug-and-receptacle assembly for single-conductor
tail-lamp cable with fuse in trailer
58d Variable-intensity instrument-panel lamp, tail-lamp and
side-marker lamp
58L Side-marker lamp, left
58R Side-marker lamp, right; license-plate lamp
ALTERNATOR (magneto, generator)
59 AC voltage, output
Rectifier, input
59a Charging armature, output
59b Tail-lamp armature, output
59c Stop-lamp armature, output
61 Alternator charge-indicator lamp
TONE-SEQUENCE CONTROL DEVICE
71 Input
71a Output to horns 1 & 2, low
71b Output to horns 1 & 2, high
72 Alarm switch (rotating beacon)
INTERIOR
75 Radio, cigarette lighter
76 Speaker
77 Door-valve control
SWITCHES
----------(Break-contact and changeover switches)----------------------
81 Input
81a 1st output, break side
81b 2nd output, break side
----------(Make-contact switches)--------------------------------------
82 Input
82a 1st output
82b 2nd output
82z 1st input
82y 2nd input
----------(Multiple-position switches)---------------------------------
83 Input
83a Output, position 1
83b Output, position 2
83L Output, left-hand position
83R Output, right-hand position
CURRENT RELAY
84 Input, actuator and relay contact
84a Output, actuator
84b Output, relay contact
SWITCHING RELAY
85 Output, actuator (end of winding to ground or negative)
86 Start of winding
86a Start of winding or 1st winding
86b Winding tap or 2nd winding
----------(relay contact for break and changeover contacts)------------
87 Input
87a 1st output (break side)
87b 2nd output
87c 3rd output
87z 1st input
87y 2nd input
87x 3rd input
----------(Relay contact for make contact)-----------------------------
88 Input
----------(Relay contact for make and changeover contacts (make side))-
88a 1st output
88b 2nd output
88c 3rd output
88z 1st input
88y 2nd input
88x 3rd input
ALTERNATOR and VOLTAGE REGULATOR
GENERATOR and GENERATOR REGULATOR
B+ Battery positive
B- Battery negative
D+ Dynamo postive
D- Dynamo negative
DF Dynamo field
DF1 Dynamo field 1
DF2 Dynamo field 2
----------(Alternator with separate rectifier)--------------------------
J Excitation winding positive
K Excitation winding negative
Mp Center point terminal
U,V,W Alternator terminals
DIRECTION INDICATOR (turn-signal flasher)
C First indicator lamp
C0 Main terminal connection for separate indicator circuits
actuated by the turn-signal switch
C2 Second indicator lamp
C3 Third indicator lamp (e.g., when towing two trailers)
L Turn-signal lamps, left
R Turn-signal lamps, right
Old November 27th 2006, 10:18
Wow, thanks, It all is a little clearer now. Now I actually what those numbers mean.
With that in mind, Turn signal flasher feed is 49, which I dont have. All I have is 49a which is output to the indicator lights.
Old November 27th 2006, 14:34
TURN SIGNAL FLASHER
49 Input
49a Output
It looks like the 49a is the output from the flasher to 49a on the column which get switched to R or L signal output to the lights. So that is the input on the column you are looking for:agree:
Old March 28th 2007, 13:52
hemitheus hemitheus is offline
I have their kit in my 74... i just used their ignition switch as well, pulled the wheel lock mechanism out of the column.
